Shore Power Cords
Tiki Time
I have two questions for the Captain.
1. How long should a power cord be. I have a 30' boat, and stay at marina's on weekends.
2. I have a power cord and would like to know the best way to clean it up, and take the black scuff marks out of it. Thanks!
Needs to be long enough to make it from the power source to you plug on the boat.
Don't know how to clean them, maybe some dish detergent?
Acetone cleans them up real nice! After cleaning give them a good coating of 303 vinyl & rubber protectant. I saturate a rag with it and pull cord thru it. Look like new when finished.
If only 25' will serve your needs then go with it. Even tho they are 10 gauge conductors; there's always a voltage drop over distance.
We frequently travel to other clubs and marinas, and I've foung that the 50' cords work best. Sometimes we find the dock power right where we need it, but mostly it's down the dock a bit.
There is a product sold in Home Depot called Krud Kutter. Works pretty well on cords and fenders.
Spray 9 works for me we carry 2 sets of cords 2-50' and 2-25' then we can pretty much do any combination. I like using the shorter cords there is less voltage sag when running the AC units.
I find acetone sure cleans but, left like that, the cord becomes sticky and gets dirtier. I like Bob J,s response to protect after cleaning and will use that idea in the future.
Mr. Clean Magic Eraser moistened well with 303 instead of water works pretty well on electrical cords, hoses and any vinyl. No harsh chemicals and the protectant goes on at the same time. Just wipe lightly with a clean rag as last step.
Aurora products. The same system they recommend for the hull.
Yrs. ago used acetone, and didn't treat and got the stickies. Now I use 'oops' from the hardware store and a majic eraser. We have a Glendenning cable master, and if I treat the cord the retrieving wheels will not pull the cord in. Too slippery.
Less than 50 foot gets to be a hassel of always being too short. a single 50 footer works 75% of the time. Carrying a second 50 footer does it for the other times. Also accumulate a set of adapters over time; 20 to 30, household plug to 30 and find a 220/50a to 30a adapter. Quite often a dock where all the 30amp outlets are full will have a 50a unused becaused nobody uses that.
50 feet.
Clean it with acetone, Interlux vinyl prep, or the best vinyl cord cleaner of all (IMHO) Restoration Technology Marine Strip.
Then coat it with multiple coats of Mop and Glow. It will shine like new.
good old fashioned cleaner wax does a great job and its not to slippy for the glendining unit to grab it when its done. helps cut down on the future dirt with a little bit of protection. if you only need one cord a single 50 will do most of the time if you travel. i leave one at home the right length from the pedestal and take it with me as a spare when i travel.
When I worked on electronics in the field, the vinyl handles on my tools would get dirty. I found that the lanolin based hand cleaner (not the gritty kind) worked really well on them. I imagine it would work well on power cords without the chance of damaging them.
Sorry I havent got back sooner,been out of town!Thank You for all of the advice! I learn alot on this forum!
I got 2 new Shore-Power Cords yesterday for the price of 2 quarts of Acetone and some Wax to put on em after to prevent the stickies.
