considering "starting batteries" why do you need a charger connected?
If you did your maintanance of checking: service time,connections, fluid levels,hold downs,charging voltage, alternator output etc. the battery should not let you down. Had a customer get towed because all 4 batterys would not start 1 motor.All 4 were cooked dry but he got 1 last start when he left the dock.As far as AC accessories are concerned,start the genny and then switch
over to it for the AC stuff.
Battery chargers should only be connected to "ships battery`s " not starting battery`s.
1 Shore power/water supply hose
2 start eng, start gen.(if equipped)
3 stow gear during warm-up, check gauges,exaust water flow
4 cast off and have fun
