Shore Power
Ladyhawke
Please help me....
We have a Chaparral 250 which has a 30 amp electrical system. We are getting ready to have our first overnight stay at a marina and I have some questions regarding the shore power.
I was told to have a 50 to 30 amp adapter available. Okay...no problem...except when I went to buy one, I was asked if it was a dual voltage or single 50 amp outlet! I don't know....I didn't know to ask!
I tried looking some on the internet but was not getting any good information within the first 3 pages of google.
What I want to know is:
1. What does the amperage signify?
2. What is dual amperage?
3. What kind of amperage do most marinas have?
4. Is there anyway to avoid having to buy so many adapters?
Thank you for any help you are willing to impart!
If you are at a marina, chances are that they will have a 30 amp shore power outlet next to your slip. Your boat has a 30 amp shore power connection. You need a standard 30 amp shore power cord that you can buy at any marine store. You probably have a 30 amp cord on your boat. Unless the marina has a jackleg electrical system, you won't need any adaptors, just a standard cord.
How do you plug your boat in to shore power now?
1. Think of amperage as the flow rate in a water hose. A larger hose will move more water. Voltage is like pressure.
2. Dual "voltage", maybe? Some 50 amp connectors can be used for either 120 or 240 volts. (As you now know.)
3. 30 amp / 120 volt is the most common, with 50 amp / 120 right behind. 9 times out of 10, you won't need an adapter, and often, the marina can supply with with a loaner if you do need one.
4. Call ahead, and select your marina accordingly.
OK, I didn't read the original post very well. If the marina has 50 amp outlets, most likely they are 240 volt, 50 amp. The only adapter I know of is a Y splitter that you plug into the 240-50 and you can plug 2, 120v-30amp power cords into. I think those Y splitter adaptors run around $200.
I can't believe a marina doesn't have any 30 amp power outlets.
Ditto cwms. Twin 30 amp is the standard on the power pedestals here. How many inputs does the Chap have. There is one a few slips down from me. It is a very well equipped boat and has twin 30 amp service. Have you called the marina where you are spending the weekend? I would be willing to bet the standard setup is twin 30's. If not, a 50 amp to twin 30 splitter will give you 25 amps per side. Not perfect, but I have used it with no problems as full draw on either side all at once is highly unlikely.
HTH
The short version is, you almost never see single voltage 50a 125v 3 wire outlets anymore. They pretty much are all 125/250v 50a 4 wire outlets now.
Look at getting a single 50a 125/250v to two 125v 30a splitter.
Or you could make your own single 50a to single 30a adapter. Not sure if they make those anymore.
We have one input on our boat. I was told by the person directing this cruise that the marina has 50 amp service. I will be calling tomorrow to get further details. I just got really confused when the salesclerk asked about dual vs. single voltage.
There are a lot of places around here that only have 50 amp power. But we don't mind, because a lot of them run between $5 to $40 per night, no matter the size of boat.
So we deal with it and buy a Y splitter, 50 amp male to 2 each 30 amp female.
Ladyhawke,
Just tell the marina all you need is 1 - 30 amp connection. Most marinas have both 120 volt/30 amp connections and 240 volt/50 amp connections for the bigger boats.
On my boat, I have 2 - 30 amp connections that I can either plug into 2 - 30 amp shore connections or I can use a Y splitter and plug into 1, 240v-50 amp connection.
"We have one input on our boat. I was told by the person directing this cruise that the marina has 50 amp service. I will be calling tomorrow to get further details. I just got really confused when the salesclerk asked about dual vs. single voltage."
Well, if there is another boat that only needs one 30a cord, the two of you could split a 50a to 2 30a adapter if your cords would reach.
Most 50 amp splitters I have seen are 1 each 220 volt input that splits to 2 each 110 25 amp outputs. The splitter does that automatically. If that is the case, all you need to do is cap the unused end or share it.
One correction Kida. The split from a 50amp 220/110 outlet is into 2 x50 amp 110V, not 25 amp. There are two legs of 110 each with 50 amps. If you run that as 220, you still call it 50 amp (on both legs). But if you split into two separate 110v outlets, you call it 100amps total.
Anyway, there IS such a thing as a 50 amp straight to a single 30 connector, but they are rare. Cheaper, but a Y splitter is easier to find. Plus, then someone else can use the other leg too.
We just returned from a long trip from Michigan to Ohio and twice we ran into 50-amp service only. In both cases the marina supplied the adapter. One was free with a large refundable deposit and the other was a $20 rental. These adapters are not cheap so call and see if they provide.
Good luck
Niles
Thanks. I did not know that. Learn something new every day. Not to hijack, but does running the 50 amps into a 30 amp vessel pose any danger?
"The split from a 50amp 220/110 outlet is into 2 x50 amp 110V, not 25 amp."
While technicaly true. It's still called a 50a to 2 30a splitter. Because you can only use as many amps as the lowest rated plug/cord.
"but does running the 50 amps into a 30 amp vessel pose any danger?'
No. You are not "running" amps into anything. There are just 50 amps sitting there to use if you could.
well, if you have a short in the inlet on the boat side or in the wiring between the inlet and the main CB, you can still pull 50amps before the breaker on the dock trips...
marinas usually have the typical power for the slip side. 50amp is rare on boats under 30/35 so a 25 to 30' slip should have 30amps service. usually both. I cant' imagine buying an expensive adapter for a rare occasion like this, marinas somtimes have adapters, give them a call.
as to the store clerk not knowing what he was talking about... well, west's new?
there is a good PDF on the Marinco site that explains everything you need to know about shore power, cables and adapters
http://www.marinco.com/docs/guides/Boater'sGuidetoACElectrical.pdf
A short would 'pop' the breaker rather quickly. Sparks may fly whether it were a 30amp or 50amp main CB. However, if your onboard 30amp breaker were to fail closed(and not 'pop' the main breaker at 45 or so amps) then you could be drawing higher than rated amperage through a cord that may overheat over an extended period of time.
We've been all over our area MA, CT, RI, Long Island and have 50 amp, 110v service in many marinas so your really have to get the details form the marina before you buy anything. Also many marinas provide adaptors; some charge some don't.
"well, if you have a short in the inlet on the boat side or in the wiring between the inlet and the main CB, you can still pull 50amps before the breaker on the dock trips...'
For like what? A half a second? :-)
"We've been all over our area MA, CT, RI, Long Island and have 50 amp, 110v service in many marinas"
Is it 3 wire 50a 125v service? I'm only asking cause I never seem to see that anymore. And I don't know of any new boats wired that way anymore either.
