Should I do a compression check?
JeffR
I bought a new-to-us boat this past winter - it's a 2005, 6.2 Mercruisers, with roughly 55hrs on them. I had a full hull survey at the time, and was planning an engine survey of some kind very soon. BTW, I've held money back pending sea trial and engine survey. HOWEVER, I've purchased the boat in a somewhat remote location that caters to smaller inland fishing, and I'm having a hard time locating a Mercruiser shop that is equipped fully to check ECM for hour accuracy, etc. There is a Mercruiser shop in the area that has Mercruiser trained techs, and know I could at least have one of the techs do compression checks. I've asked several shops their opinion, and surprisingly, they unanymously said they wouldn't worry about it on an '05 with such low hours. Now I'm starting to wonder if I need to do it. I will still do sea trial and check sytstems, WOT rating, etc. Oh, the engines are still under transferrable warranty.
What's your advice? Are the hour verification and compression checks necessary, or is it actually a little overkill for the year and (displayed) hours?
This has been discussed many times here, but a continuation of this discussion, in my view, is a good thing. What you are asking is if you should continue to do your due diligence. As the cost is low when compared to the risk, and you just never know, the obvious response is yes, you should perform all of the usual and customary checks, and that includes a thorough mechanical inspection in conjunction with your sea trial.
There is no way to ascertain, with as close to absolute certainty as possible, that everything is as it should be without doing a full and complete mechanical inspection. You really should know everything possible about the boat and its systems upon which you'll base your final decision before you close, not discover that something is awry after you close.
In the for what it's worth department, the time for the compression reading is after the sea trial when the engines have already been run out and are still warm, not now while the boat is still in its winter storage mode. For peace of mind, skip nothing.
My 2-cents...
i agree with bill... a compression check on a gas engine is easy to do... removing the plugs is important anyway to see how the engine runs so stickign a gauge in there and cranking for a few sec is a no brainer, even on a fairly new engine. although 3 years is 3 years... corrosion never sleeps!
It's always good to do an initial compression test. If nothing else, you have a baseline with which to compare later tests.
Jeff, YES do the check even if merc' attempting to dissuade you, figure at least $9K each to replace engines,and thats lowball,depending on make of boat,3 years old w/only 55 hrs,sounds great...BUT,it depends on how and under what conditions the boat was "stored" for those 3 years,alot of corrosion can develop in 3 years contingent upon "storage" or docked/drydocked conditions.
