I’ll stick my neck out with some comments .
Interesting how many boats have adopted the deltaconic idea. Other than the depth of the Vee the Hatteras and Carver hulls are remarkably similar. Deepish forefoot for wave braking Vee and keel for stability flat "chine shelves" for speed and roll resistance.
Notice the curved shape of rudhons Crirs. Probably for smooth ride at the expense of pure speed and roll resistance.
I don’t see anything in Flywrights hull to make me say semi displacement. Given enough power that is a planning hull with all those straight runs aft and flat sections IMO though it may be operated and powered to be no faster than semi displacement mode.
Poco’s hull has many true trawler aspects.The only one shown so far Full sections forward and hull rises toward stern to reduce drag but doesent quite make it to avoid a square transom and reduce drag.
Old salts boat was designed for lift and speed.
Andys boat says speed. Immersed hull seems narrow for the overall beam but that might just be perspective of the PIX. Prop pockets add efficiency while reducing slow speed maneuverability and increasing wake at other than fast cruise. And a smallish keel for improved tracking.
Many hulls are designed to run on a narrower surface when on plane for speed but immersed wider beam at rest for added roll resistance and increased slow speed lift to help get up on plane. I put delta conic and possibly Andy’s in those categories.
Nwaring’s mainship looks to have rounded chines. If so that reduces roll resistance but also reduces drag. Not much lift to plane.
How am I doing??
How am I doing??
