single handed docking
clmb511
I'm looking at Chaparral 35s and the Silverton 35 and trying to figure out if there is any way to dock the Silverton without assistance. Even the Chap would be a challenge enough.
Does anyone have any thoughts/ recommendations on this?
Probably 30-50% of the time I will be docking single handed, so it isn't a rare problem for me.
Docking how? Stern in? Broadside? What type of dock? How can we answer you with no information?
either one you should be able to dock single handed. I assume you are talking silverton 351 MY? Regardless, both are twin screw boats and both can be easily handled solo.
Many do it, it can be done, all it takes is someone to show you how and lots of practice.
it's all about preparation, boat size is irrelevant... actaully the larger the boat the easier it since a heavier boat will not be blown around by the wind.
sail area, weight, hull shape are a factor. a flat hull, large cabin and light boat will be worst...
Preparation is key. I alwasy singlehand my 53 but I have a lower helm with side doors that put me within steps of my springlines, making it very easy. on an express, you need to rig your fenders and lines before approaching the dock. My previous boat was a maxum 37 and i used a 50' bow line with the bitter line in the cockpit. When the boat was alongside i could step on the dock at the stern holding both the bow and stern lines.
at your slip, you already have lines rigged and ready so size isn't an issue, deck access is. the first lines you will normally secure are your spring lines (to prevent the boat from backing into the dock) so you want safe sidedecks from which you can grab the line. a telescopic hook is a great tool...
when docking the 35 siverton alongside, the best option is to come at an anglem with spring line rigged from the midship cleat. throw the line on the dock from the bow holding the bitter end to catch a cleat then tie it back to the cleat. return to the helm and go forward on the spring line to bring the boat along side then secure the stern line. it takes a little practice to catch the cleat, again a long hook can help... that's what i do on my boat.
the key is also to realize that these are larger boats and you can't do small boat stunts like pulling in with no fenders, no lines, and jump off the bow. once you get that, it's easy to see how you can use your engines and lines to do whatever you want.
The express shudl be a little easier to single hand, but it all depends on your experience.
Shouldn't be an issue (with v-drives). I do it all the time in the 340 which is the same size as the 350S. For me, stern-in is much easier than bow in. The bow can be a little tricky to control in a strong wind, but you get used to it. I leave my lines on the dock, so that makes it a much quicker task.
i single hand minr all of the time. no real issues. i am a stern in with a 25' finger pier.
My interpretation is that a DOCK is a flat faced wall in the water that one berths alongside. This is totally different from a finger slip or getting in between piles.
No matter. If you have a springline & know how to use it, singlehanding, even with a single IB is not that big of a deal provided wind or current extremes do not have to be dealt with.
I single-hand my 350 Carver Mariner all the time...and I'm not a boating expert by any means...planning is key.
Not to toot my own horn but I'm a single person "docker" always. Even when boat is full of people.....actually, that makes it even worse. Just learn your boat, memorize the wind as it relates to your slip and just "prepare prepare prepare". Always have the "abort" maneuver perfected.....
Ego's and docking do not mix....
LOL rb2@gr5t what dwarren said (Even when boat is full of people.....actually, that makes it even worse)...sometimes that is very true! And yes...never be afraid to abort...
Practice baby, practice. And just when you think you have it down...practice baby, practice. Oh, and that fire extinguisher pedestal that you could see a few seconds ago that you cannot see now is still there and subject to being knocked over by your bow flair, thereby setting off the alarm and putting a huge dent in your ego. Not to worry though, They are pretty tough and only take four 10X1.5 inch sheet metal screws to put back together.:)
I single hand a Sea Ray 370 Sedan about 80% of the time. Stern in to a narrow slip with a sailboat sticking into the fairway about 6' on either side. I have a set of lines that I leave on the dock and another full set for trips abroad.
I practice a lot and in all weather conditions. If I think its dicey, I'll actually stop outside the marina and see how the boat is reacting to the wind prior to approaching the marina/slip.
One thing that really helps is bow flags - it let's you see the direction of the wind...when I've got the canvas up, I can't "feel" the wind (on my face) so I make sure to watch the flags for wind direction...when I first started "winter" (in Texas) cruising (with the canvas up) I had a close call in the marina...had the wheel straight in the fairway coming in one night...didn't realize that the wind was blowing as bad as it was...it was pushing me sideways very very near other slips...watching the flags when I get near the breakwater/no wake zone coming in makes a world of difference...at least for me....I just crab into the wind and the boat goes where I want it to.
Is there a way to dock without assistance? Depends upon conditions, and one of them is your skill level. Only you can judge that.
Then, there is the tool available, your boat.
See which alignment (stern-to-wind or bow-to-wind) gives you the best control for holding position in a marina fairway, when the wind is strong. For the Chaparral, at least, I suspect it's stern-to-wind. Whatever you find, let that be your instinct, if conditions are snotty. It'll help keep you away from a lee shore.
If you have gas engines, you'll probably need to employ some throttle in less-than-ideal conditions, to get adequate helm response.
Break a job down into a sequence of single tasks, each of which you can do. Stay within your skill limits, as you gain savvy.
What kind of dock setup?
How is the water, is there a strong current?
Is there much wind?
Twin engines make it pretty easy to maneuver the boat. It's all a matter of getting used to how much speed the boat NEEDS to maintain effective steering. Going to slow when there's a lot of wind and/or current can really make it difficult. But I'm talking the difference between 3mph and 5.5mph, you'd be surprised how much 2.5mph affects things.
I single-hand our 34' express cruiser regularly. We keep a set of lines attached there. That and I've got a couple of well-placed fenders and some dock edging to keep the boat from getting scratched. Our marina is pretty calm though.
I always make a practice of telling everyone to sit still and not do anything.. People start pulling this way and that.. Ruin a perfectly good approach.
"ruin a perfectly good approach" Or manage to get themselves hurt.
