Single vs. dual props? Significant difference wit
YAMADOG
Single vs. dual props? Significant difference with Twins?
So lets say you are looking at a 30 footish cruiser, with twin engines. What are the significant differences between going with a single prop (Merc Alpha/Bravo, Volvo SX vs, Merc BIII, Volvo Duoprop)? I know it is a significant difference in single engine installations, where the twin counter rotating props help to negate the natural tendency to turn from the engine torque effect, and I know that they tend to get a better 'bite' on the water. But in a twin installation (I assume pretty much all twin I/O installs are counter rotating these days?!?), how much difference is it. Are the differences great enough that you would not consider a boat with say twin SX, single prop, drives?
Two engines mean higher initial cost and double the maintenance/repairs. However, provided each engine has its own dedicated fuel tank/battery bank/etc, the redundancy give you more insurance that you can limp back to the dock in case of a failure. Your fuel mileage will be better with a Duoprop configuration, but docking is more precise with twins.
Pick your poison......
If for no other reason, a 30 footer has more weight. Twins will move it along comfortably and efficiently. The very worse thing in this world is an underpowered boat!
I believe he is asking about the differences of a duo-prop vs. single prop on a twin engine 30 footer....not single engine vs. twin engine.
If the single prop outdrives are counter rotating to each other, I don't see any significant benefit of a duo-prop set up. They may have better bite and reaction but I can't speak from experience as I have inboards.
AH! Well then, if already a twin engine, then the one single advantage of a dual prop is the stern lift they provide to get up and out of the hole smartly.
my bad [:-paperbag]
More efficient conversion of hp to thrust. With fuel prices what they are, I want to get all the thrust I can get out of a gallon of gas.
With a single prop you get into the "Black Art" of tweaking a prop/engine/hull setup for max efficiency. And that's another place where outboards are far more efficient than I/Os. The "X" dimension on I/Os is fixed. On an outboard you can tweak the height of the engine and gear case and prop to maximize performance, especially with hydraulic jack plates. But, barring the adjustability inherent in an outboard setup, the twin prop setup will probably be very slightly more efficient. It will also weigh more and that is more weight to push. And it's more complex and has 4 props instead of 2. SO initial cost will be significantly higher and maintenance can be much higher too, especially if you hit something. Will a slightly better fuel consumption number pay for itself?? I don't know.
I know that a lot of people running I/Os like to run aluminum props, figuring the prop will protect the drive from damage. May or may not, but if you want efficiency, single or dual prop, you use stainless. Better acceleration, better top end and better fuel consumption. And just don't drive it into rocks and you won't have to worry about prop or gear damage.
JMNSHO &, of course, YMMV
I can’t speak for all boats but I can for one.
With a current model 280 Suncancer, two if the available options are
Twin 4.3’s with Brabo III
Twin 4.3’s with Alha I gen II
Difference:
The Alpha I’s get about .1 better MPG, 1.6 vs 1.5.
The Bravo III’s do better getting on plane with a heavy load.
If you go with the twin 5.0’s with twin Bravo III’s fuel economy drops again to about 1.4MPG. Power increases.
WOT is about the same with all three, 45 MPH.
If I were buying a brand new boat and had the choice I would consider the twin Alpha’s simply because they are not as prone to corrosion and if you do hit bottom they are less expensive to repair.
A friend of mine bought the exact same 28' boat that I had. We both had VP 5.0 engines in them. Mine had twin duo props, his had twin single screws. We went on a 200 mile trip, he had two people on board, we had four people on board.
Overall, my boat burned 20% LESS fuel than his did.
That's because he pulled you home the next morning.
MJK
MJK
I'm sorry, was my snickering distracting??? King, are you being rude to Hogan? ;)
Who me? Never.
Sorry for stealing your line.
MJK
No, you're fine...that was your line, you say that.
Say what?
The meeting is adjourned.
It is?
The main difference between the duo props and the single props is the duo props spin in opposite directions on each drive. The result is that the first prop imparts a bunch of rotational energy to the water and the second prop reverese the effect and the water comes off of the duo props with very little rotational energy, basically shooting the water out in the direction of travel. This makes them fundamentally more efficient as rotational energy imparted to the water is longitudinal energy lost.
Although my 280 Sundancer has twin Alpha 1 outdrives that run great, I would be just fine with duo props..
