Siphoning Gas
  • Thread starter Thread starter blouderback
  • Start date Start date
B
blouderback
Guest
Any tricks to getting a 1/2" clear hose down the gas fill tube so I can siphon some old gas out of the boat? I tried 3/8", and then 1/2", and couldn't get past a certain point. Then, just to make sure there wasn't some anti-siphon device installed in it, I fished a electrician's fish tape down it and it went right in and got wet with gas.
It seems that it can't get past the 60 degree or so bend in the fill hose.
Bob, any chance of getting to the gas via the sending unit on top of the tank?
Bob,
Had a similar problem on a sailboat where the owner (a friend) put a couple of gallons of gasoline in that should have been diesel. Had to siphon the whole tank. Couldn't get the clear tubing to make the sharp turn into the tank that the fill hose took. Ended up having to remove the fill hose and stick the tube directly in the tank. Depending on the type of tubing it doesn't seem to "snake" very well.
If you ziptie the snake to the siphon hose you should be able to get into the tank. Do not use tape. The gas will dissolve the glue and be left in the tank.
try getting a bullnose filter to go into the end of the hose. like the kind in a portable gas tank. that way the blunt end won't get caught up on anything. also try cutting the hose end at a bias.
Bob, my cousin just took 65 gallons out of two tanks for me. If you have good access to where the fuel fill enters the tank, just loosen the clamp, pull the hose off and you'll have no problem. Make sure you have enough hose and enough tankage on the ground and give it a little suck. Gas will roll right out. Some people will disagree with using your mouth I am sure but we felt it safer than using anything electrical. As long as the tank your pumping it to is below the fuel tank in the boat, it only takes a little suck to get it going. Good Luck
Why do you want to take the old gas out? Did you add Stabil or Startron or both in the fall at layup?
I did, but I felt that it would be best to put brand new fresh gas in it, and use the old stuff for the mowers and stuff. I'd rather have the weed whacker die in the middle of trimming instead of the boat dying in the middle of the river.
If the gas was pumped in last fall and stabilized it should be perfectly fine unless you have a leaky fill cap or somesuch. At least my boat is running like a scalded cat with it's approx 7 month old E10 gas.
As long as there are no spills it can't hurt if it makes you feel better. Of course, if you refuel from a dock pump now some of that fuel may be just as old & unstabilized.
But to answer your question, I'd agree with the mention suggestion of cutting on the bias and twisting the hose as it's pushed down, otherwise use the sender hole. If the hose barb fill-fitting on the top of the tank is 90* the hose may not negotiate that last turn.
Bob, it’s possible something is blocking the hose. You need to take a look.
Now Bob, it’s going to be dark looking down that hose so you need something small that you can hold between your fingers that will add some light as you look into the tube.
On a completely different subject, a match generates a lot of light, is small and can be held between two fingers.
OK, back you your problem Bob. I don’t know what to recommend you use to light up the hose. Maybe something will come to you.
I'm no moderator, I may be out of line, but this is a public forum, here we are offering advice on siphoning fuel from boats for the unscrupulous that walk amongst us.
Just my $.02
We use something called Super Siphon to put gas into the tank from a portable one. My guess is that it would work the same to siphon gas out of your tank. It's one of the best little gadgets we've ever had. If you Google "super siphon" you'll find one.....get the one with the brass fitting, not plastic. I love mine and have had it for years.
Bob, unless your tank totally full, pump fresh gas into the tank and you should be fine, even with the old gas I wouldn't worry...
I wouldn't bother pumping it out. The gas should be fine. I've kept gas much longer than the winter without issue.
Doug
Doug
Diito
"I'm no moderator, I may be out of line, but this is a public forum, here we are offering advice on siphoning fuel from boats for the unscrupulous that walk amongst us."
Believe me ... the thieves KNOW how to siphon gas!!!
My suggestion to Bob, not to bother, if the gas was stabilized his boat should run just fine.
Doug
Diito
Ditto Ditto
Add as much fresh gas as you can as often as you can for the next couple of outings and you should be fine. I ran my boat 2 years ago after it sat for 2 years with no use other than getting it ready for summer and re-winterizing. So that gas, stabalized, was at least 2 years old. I had no problems.
Try putting your electrician's fish tape inside your siphon hose. This should make it stiff enough to allow you to get it into the tank. Pull the tape out of the hose once the hose in in the tank.
