Sizing a flag and it's usage
TimHenn
I realize this is likely a topic beat to death but I didn't pull anything up using search.
What is the rule for sizing a flag -- my current understanding is 1 inch of flag pole for each foot of boat length (I assume LOA)... So a 40' boat would have a pole 40" and the flag would be roughly 20" - is this correct?
Another question, if you have a small pendant flag on the pulpit is there an expectation, in pure nautical speak, of what should be displayed in particular situations?
Hope are having a great Memorial day weekend.
Tim
i dont' think the pole size is relevant, a pole twice the size of the flag woudl often look odd...
I usually go by the 1" flag / 1' boat "rule", or just under... I have a 48" flag on my 53 footer although you probably don't want to go that big on larger boat. Can't really imagine a 6' flag on a 70 footer...
Agree with Pascal, one inch/foot . 20" flag would look too small on a 40' boat. You can fly what ever you want off the pulpit, however the American flag shouldn't be flown there.
I fly a 36" flag from the stern of my 36' boat and I have a Yacht Club Burgee on my bow. The burgee comes in hand for judging the wind when I come into the dock.
The pictures of these stainless poles
(http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/161192/377%20710%201189/712/flags/Primary%20Search/mode%20matchallpartial/0/WMPrice%7C1?N=377 710 1189&Ne=712&Ntt=flags&Ntk=Primary Search&Ntx=mode matchallpartial&Nao=0&Ns=WMPrice|1&keyword=flags&isLTokenURL=true&storeNum=5004&subdeptNum=7&classNum=192)
show clips at about half the pole size -- if I purchase the 48" pole what size flag should be purchased, maybe 36". Pascal, if your flying a 48" flag what is the length of the pole?
Tugboat Kevin, lol, 12 feet by 18 feet is really big :)
48" is the flag length, so i'd guess the pole is about 42...
I have the same 48" pole you referenced in your post. I have a 48" flag on the pole. The pole is mounted to the top of my transom. I like the look of it as the pole seems to be about the right size for that flag. The pole is angled back a bit so even though the bottom of the flag is below the bottom of the pole it does not rest on the transom, it hangs behind it. The previous owner of my boat had around a 20" or 24" flag on a small pole and it looked really small. The size of this flag fits the boat well. My boat is around 50' overall length. I like the stainless pole vs. a wood or aluminum pole. The clips on that pole are adjustable but the lower clip will be about halfway up the pole with a 48" flag (the flag is 48" x 30").
I generally fly a Boise State flag off the bow pulpit. As Michael indicated having a flag on the bow really helps judge the wind when in close quarters.
Kris
Just purchased a flag and pole on line from West Marine. Their suggestion for sizing is 1" for every foot of boat length and the pole should be twice the vertical dimension of the flag. So I got a 48" flag for my boat which is 53' overall and a 48" pole. If I used their rules the pole would have been 60" but that seemed to tall for where I want to put it.
Ron,
Great looking boat! I put mine on the top of the transom and like the look of it there. I was thinking of putting it on top of the roof above the cockpit but thought it might get in the way of the dingy. I did not use the backing plate that came with the pole and it seems pretty sturdy. It would have been alot of work to get underneath the top of the transom to put the backing plate on. I remove the flag whenever I leave the boat so I figured I would see right away if the mount started to work loose.
Here are a couple pictures of the new flag:
Kris
