Small Craft Warning
Gerrynoank
I just got back from delivering a 44' sailboat from Annapolis,MD to Haddam,CT. It was a great trip, snowing for the first part in the Chesapeke and C&D Canal, and the winds picking up ouside Cape May, NJ all the way up the NJ coast. I proved to be a pretty good 400 mile trip with not much equipment or weather drama.
As we were heading down the Delaware we were doing the due diligence listening to NOAA and they reported gale warnings and a "small craft advisory". This created one of those fun discussions that helps while away the time on a delivery - what defines a "small craft".
I'm sure this is a great setup for jokes and one liners, we certaintly came up with our share, but I would like to find a refernece to it's definition.
The definition's in the same dictionary that has the phrase "Snow Day in South Louisiana".
RE: "small craft advisory"; "I would like to find a refernece to it's definition." -- Gerrynoank
I don't think you will find a definition. However, it is generally accepted that if you ask that question, you are in a small craft...
From NOAA:
"Small Craft
There is no precise definition for small craft. Any vessel that may be adversely affected by Small Craft Advisory criteria should be considered a small craft. Other considerations include the experience of the vessel operator, and the type, overall size, and sea worthiness of the vessel. See Small Craft Advisory."
For the definition of "Small Craft Advisory", see you local NOAA website Glossary, as the criteria for them to declare a SCA varies by location ( imo, as it should )
Long ago in CGAux safety classes, the define small craft as less then 26 ft and small craft warnings as winds above 25 kph. That was 30 yrs ago and may have changed since then.
Small craft advisory: winds up to 33KPH (38 mph). I'd define small craft as any boat I didn't want to be in with winds like that!
Guess what, it snowed last night in South Louisiana.....
My boat will handle rough water and wind pretty well. It has high freeboard, so it isn't likely to swamp. But docking is a major b[:-censored]ch!
Good to see rduhon here, there was a Chopper crash down your way today.
You got that right Liz! I'm not going anywhere near my dock in thos winds. I'd rather be "sortied"!
Considering that it is NOAA that issues the advisories, I think I will continue to accept their definition.
I've got a 26' Formula and as soon as I see "Small Craft Warnings" in the ocean it's a no go, no questions asked. However, when on my friend's 26' Glacier Bay (catamaran), it's a whole different story. That thing could handle a LOT heavier seas than most any monohulls of similar length.
So the type of the vessel to be used is also a big consideration.
Peter
My rule of thumb is if you question the conditions, better stay on the dock.
Be careful using wikipedia. It can and is written and edited by anyone. Not a reliable source for facts.
There was snow in South Louisiana yesterday.
G
The further one goes from shore, the closer the pointy end gets to the blunt end. Also what would normally be a 2' sea will become a Boater Ed scale 5-6'er.
"Small craft advisory: winds up to 33KPH (38 mph). I'd define small craft as any boat I didn't want to be in with winds like that!"
"The further one goes from shore, the closer the pointy end gets to the blunt end."
Ditto. "small" is what you want to make it. It has more to do with seaworthiness than size.
Folks have crossed the Atlantic in boats about 10' long; and I've seen times when a 900 footer was a bit "small".
SMALL CRAFT ADVISORY: An advisory issued by coastal and Great Lakes Weather Forecast Offices (WFO) for areas included in the Coastal Waters Forecast or Nearshore Marine Forecast (NSH) products. Thresholds governing the issuance of small craft advisories are specific to geographic areas. A Small Craft Advisory may also be issued when sea or lake ice exists that could be hazardous to small boats. There is no precise definition of a small craft. Any vessel that may be adversely affected by Small Craft Advisory criteria should be considered a small craft. Other considerations include the experience of the vessel operator, and the type, overall size, and sea worthiness of the vessel. There is no legal definition of "small craft". The Small Craft Advisory is an advisory in Coastal Waters and Nearshore forecasts for sustained winds, frequent gusts, or sea/wave conditions, exceeding defined thresholds specific to geographic areas. A Small Craft Advisory may also be issued when sea or lake ice exists that could be hazardous to small boats.
Eastern (ME..SC, Lake Erie, Lake Ontario) - Sustained winds or frequent gusts ranging between 25 and 33 knots (except 20 to 25 knots, lower threshold area dependent, to 33 knots for harbors, bays, etc.) and/or seas or waves 5 to 7 feet and greater, area dependent.
Central (MN..OH) - Sustained winds or frequent gusts (on the Great Lakes) between 22 and 33 knots inclusive, and/or seas or waves greater than 4 feet.
Southern (GA..TX and Caribbean) - Sustained winds of 20 to 33 knots, and/or forecast seas 7 feet or greater that are expected for more than 2 hours.
Western (WA..CA) - Sustained winds of 21 to 33 knots, potentially in combination with wave heights exceeding 10 feet (or wave steepness values exceeding local thresholds).
Alaska (AK) - Sustained winds or frequent gusts of 23 to 33 knots. A small craft advisory for rough seas may be issued for sea/wave conditions deemed locally significant, based on user needs, and should be no lower than 8 feet.
Hawaii (HI), Samoa - Sustained winds 25 knots or greater and seas 10 feet or greater.
Guam and the Northern Mariana Islands - Sustained winds 22 to 33 knots and/or combined seas of 10 feet or more.
“Frequent gusts”are typically long duration conditions (greater than 2 hours).
http://www.weather.gov/om/marine/cwd.htm
Good info because I`ve "heard" everything from 16 to 60 ft for boat size. Gerrynoank, did you deliver to Damar, Midway marina? Thats about a 1/4 mile from me.
