SmartCraft Questions
David M
I can't find two people to give me consistent answers regarding SmartCraft. I do know it is not NMEA 2000 compatible. That is the extent of my knowledge.
I would like to monitor my engine functions. Underway, I would like to be able to dial in my best RPM and trim for most efficient fuel burn.
Does the SmartCraft fuel module work off the computer or is there an inline module as is required on the Lowrance or Floscan's?
For other functions, how many system view screens would I need, or do I need separate gauges for each function.
I was going to do this all through a Northstar unit, however I am not reading great things about them for the price. I am probably going to go with a Garmin or Lowrance plotter next year.
Any and all input welcome.
TIA
I have Smartcraft interfaced to a Northstar 550 and there is no fuel flow meter on Smartcraft engines. Fuel flow is computed by the firing duration of the fuel injectors. There is no flow meter involved.
The 550 gives you real time fuel usage in both GPH and in Nautical miles per gallon.
Mine is accurate but it uses a combination of your fuel tank sender being hooked up and calibrated and the engines computer I am using the System View 5000 displays only 1 is needed, I like having 2 it gives me more flexibility. I also have my GPS hooked up through the NEMA0183 input and the paddle wheel. One display will do 2 engines it is all in the users set up menu. I have both do both engines but I can have the fuel screen/speed-useage up on one display and oil pressure, water temperature, alternator output and water flow on the other screen.
I had a System View 5000 on my last boat with twin 5.0 MPI's I got instant GPH, MPG and avg MPG. I did not have the tank sensors connected because my guages were analog. I installed the System View 5000 myself. You don't need two 5000's. It displays info on both engines. You can also use twin 1000's or System Tachs.
My current boat has a Northstar 6000i and I get instant GPH for both engines, no MPG. I have to figure that out myself. I don't think it relies on tank senders, just the injectors. It's pretty accurate though.
David...did you find the where to plug in the harnesses required for SM? The gas is measured somehow from the injectors. On our old boat the gallons used were right on and I believe the gph was also.
Good luck
Niles
