snubber for dock lines
So my slip has 4 poles and a finger pier. I am tied 2 lines at bow. 2 lines spring from front pole to mid cleat. 2 lines crossed at stern.
I have 6 inches on each side to play with.
I can't get boat off the pole or pier. I find that if I make the lines super tight it is off but then I hang boat at low tide and I can't get ropes off cleats.
I was wondering what ideas are out there. I have seen people with pulleys and ciner blocks to keep the lines taught. I need something that will work for all tides and winds but still give me the ability to release lines when needed. I could reverse lines and tie bitter end to boat on one side leav ing loop on other side.
Thanks.
Four "TideSlides" and you're done. Allows you to tighten your lines all the way up, and also have added peace of mind during storm surges. Expensive though, and if you are at a marina, pre-approval would be in order. Best prices are at the bigger boat shows.
I use dock wheels to keep my port side protected from the dock Dave but I am on a floating dock. My lines never need adjustment.
The wheels are really nice because we don't need to set bumpers when we return to the dock. They were the largest circumfrence I could find they survived the storm last Thursday night/Friday when my wind speed indicator showed a 62 knot gust. Through most of the storm we were pulling away from the dock towards the marsh. The Tide Slides might do the trick in a fixed dock situation.
not much you can do... 6" isn't enough to allow for tides.
Indeed, short of switching to a wider slip, tideslides or similar gadgets will be your only solution.
cinder blocks or lead blocks on pulleys work with small boats, not a 30 or 40 footer.
REALLY HEFTY fenders or rub rails, or fenders and "fender boards". They're a PITA but I see no other alternative other than a wider slip.
Dave........sorry to hear you only have 6" to play with.......
Wife can't be happy.
There is a lot to be said about concrete, pulleys and lines. Worked well for many in a 4 knot current and tidal river. Give it a shot. I saw and experimented with a solid block used to hold pilings and joists for a floating deck. They look like the base of a very small pyramid. Drill it with a hammer drill and hold an eye bolt in place with quick setting compound. I have not seen it fail yet.
Good luck.
I have a similar situation - but have more than 6" on both sides. I use 50 lbs on all of four pilings together with a spring line on a pully. Takes some adjusting/expermentation, but its held us for 6 or 7 years now.
I agree, in as much as it is possible, move to another location more suited to your boat.
A floating pier, with floating side finger pier would be great. And in this case, if there's a pile on the opposite side of the bow from the the finger pier, add a TideSlide to it. You then can alleviate fenders against your boat on the finger pier side, by keeping the boat floating in the middle of the slip. Now no fenders mar your boat's topsides. You can tighten everything down snug, and the boat is then well prepared to ride out any reasonable storm which may come along.
