Soft deck over cabin question.
Beechwood297
Looking at a boat that is nice except deck flexes when walked on. Is this a serious problem if we just dont walk on it?(not a big deal to us) Is it a hard fix? Seems like something we could live with if we get a great deal on an otherwise nice boat. I would be getting a survey. 1984 Regal 277xl
Thanks for your thoughts.
That's a BIG problem and costly to repair. You might want to walk away from this one.
I would at least have a survey completed before buying. Get a professional opinion.
If you do follow up with a survey, be sure to ask the surveyor to specifically check and comment on this issue. Good luck!
How do you use a boat without walking on a deck? I assume your talking about a foredeck here? Yes, big problem and suggests future problems as whatever the deck is cored with get more rotten from water intrusion.
Soft spots can be fixed; if the whole deck is soft, then water intrusion has caused considerable damage. Get a survey and an estimate for repairing the deck before agreeing on a price.
OK, first, no one can give you a definitive answer based on what you know and explained so far (sorry if any ROs are offended but really....). Is it simply flexing a wee bit or is it soft. Big difference. A soft deck indicates water intrusion and a wet core, probably balsa but could be plywood. Some fore decks will have a little flex even if everything is OK. If it is water intrusion into the core it can be serious (depending on big an area is compromised)but it can be repaired. As said before, a qualified survey will be able to quantify the issue. If you like the boat and a soft deck is the only issue you may be able to make a good deal and have it repaired.
Get the survey!!
