Sonar/GPS Chartplotter Combos
bmaas00
I'm looking at upgrading the ancient Garmin fishfinder that came with my Uniflite. Right now I have a portable GPS and a separate fish finder mounted in the cabin.
I'm think of buying a sonar/gps chartplotter combo. Specifically, a Lowrance (LMS-522C iGPS) that costs about $650 including the transducer. The antenna is built into the unit. I just need to know if these combo units are all they're cracked up to be. I'd really like to know if anyone has a strong opinion about using one or sticking with separate units. Thanks in advance.
They can be great, especially with limited space for multiple screens or limited budget. But I'll caution you against getting a dual unit with a small screen. IMO, the screens on the compact units work OK for navigation, or for sonar, but are NOT good for splitting the screen. It's simpley too small.
I have a Garmin 4208 with sonar. That's the minimum screen size I think works to have split data on the screen, even to split the sonar read out. The way I usually use mine is to have the screen split in half or a three panel view, with bottom read out on one panel, a nav screen on a second, and the "fish eye view" on a third. It really helps me stay on track and view where I've been / want to go, without constantly toggling between screens.
Bmaas00, Lawrence makes a good unit, however with a built in antenna, I wouldn’t recommend mounting in the cabin – you may not pick up the signal. Also the 5” screen is really small for a combo. I have no problems with the reliability of today’s combo units but I would want a larger screen. Jerry
