yes pete, you def need chain. at the very least a shackle and short length of chain. it will protect the anchor rode from abrasion and damage on the bottom from what ever you anchor in. a splice directly to the anchor is not good. use a thimbal to splice an eye into the anchor line and then use a shackle to the anchor if you choose not to use anchor chain. if you have a windlass you can splice the anchor rode directly to the chain, just verify the size of the chain your windlass gypsy is rated for before you buy the chain. there are many articals on anchoring on this website, check them out, they will help you alot.
