Standard CP1000
L Hall
New member
One of our suppliers got a batch of remanufactured CP1000s at a good price - they are upgraded to accept C-Map Max cartridges and come with the full "as new" warrantee. We bought the last three that they had. They are $400 less expensive than a "new one." We've sold a bunch of these in the past with no complaints. I wanted to give you guys first crack at them.
http://www.boatfix.com/bykeywordnew2ele.asp?textfield=cp1000c&texttype=2&submit=Search
Originally posted by Northern Ivy
Thanks, Les I snatched one of these up! Now I have questions though I wil drop you a PM or email.
Any know if the Standard Horizen CP1000 water proofing problems have been corrected?
I checked on a few things and the CP 1000 is a pretty good price through the regular channel of online purchases. I've seen it a couple bucks less somewhere? I did see a few other iteams much less elsewhere. The colormax 15 is a couple hundred less at some other places. Its easy enough to go shop if you already know what you want. From my point of view a picture looks nice. It still isn't hands on.
Scottath--you are going to buy marine electroncis from a place which sells toys, lawn care, Lionel classic trains etc? Stick with a marine supplier with a sterling reputation--you run a significant risk from these multisale places, lots of scams out there!
AND: Don't forget supurb customer service. Someone to go to bat for you should something go wrong with the item. For a mere pittance, it just isn't worth it. (although, you ought to check the shipping & "handling". BoatFix has NO HANDLING charges! and only actual shipping costs.
Don't hold Les's feet to the fire for what you perceive to be a slightly better deal--it likely isn't.
for $1089 that is one heck of a chartplotter.
i absolutely love mine.
Ya guys. I insinuated in an earlier post to the cp1000 elsewhere was only a couple bucks less. I've had 3 new cp1000 and still have 2 of them. Absolutely the best as far as electronics design for ease of use and appearance. The ball was dropped on design for water resistance. The 3 year warranty losses its value when you can't have one thatr works on the boat. Standard has done a good no questions asked on their warranty service. For you guys who can keep them in a pilot house or an inclose cabin stearing station it should be an obvious first choice. I get 2 to 6 drops of water on it ever day and it hasn't held up well due to the cellofane tape water proofing on the inside.
Can you keep it in a waterproof see through bag? That would make it last longer unless it gets dropped overboard....[:-bigeyes2]
Good suggestion flutter. It probably woulh be much easier to put a 2 gallon baggie over it. Then just put a new baggy on when its to clouded to see through it... I wonder about a heat build up problem arising... What I am doing now is thake the cp1000 off and let the water dry out of it and it starts working properly again. It seams a couple of drops on the circut board messes it up. Heat might blow the screen or something???
It sounds like crap to me, I can't imagine having to wrap my GPS in a bag.
my buddy is a captain on a tug boat. he gave me somethingn to think about.
they never ...i mean never turn off there electronics. he put it to me this way...
how do you get condensation?
how does the process of creating condensation compare to the heating and cooling of your chartplotter and other electronics?
i stood back and thought about it.....now i only turn my electronics off if i am not going out for a week or more....
i put my radar in standby, and dim the screens on everything.
We've sold a bunch of the CP1000s and have never had a complaint about condensation.
There was a brief thread about condensation on another board several years ago, but no complaints from thousands who use them regularly. Standard Horizon stood up and took care of those units. They are not submersiable--if you are in a situation where it is submerciable, then you need to build an appropiate case. I have seen them used in rescue RIB's without problem--just a clear plexiglass with a gasket over the top. I have owned three SH units all were in open cockpit boats and no problem. But I kept the cover on when not in use, took them inside when it was raining hard etc.
well Navman. I like the way the user freindly format is so much I'm willing to try anything. After 3 brand new machines and finaly opening one up myself to see what was going on to find how easy it is for water to get through their water proofing system (double sided sticky tape which probably starts peeling itself off after pressing a button x amount of times) I need to find a better machine. I just haven't found one as practical with the exception ythe water resistance.
