steering column removal
sportfury
I have a 1981 Seaswirl that has a loose steering column. I don't know how to remove it from the helm. It is a mechanical cable driven type steering. Does anyone know how to remove the column? I have removed the steering wheel, but that's as far as I can get.
I believe it is the rack and pinion. Cables run from the steering wheel to a a gear in the outdive.
Are you trying to remove the unit from the console or the shaft from the unit? If the former remove the plastic cover around the shaft and you should be able to access the mounting bolts. If the latter I think you'll need to replace the whole thing.
The mounting stud is broken. I can't seem to get the plastic collar (the one that says port and starboard on it)off. Is this just pressed on and needs a little force?
Without a pic or at least knowing what kind of steering unit you have, it's hard to say. But the plastic collar is nothing but "trim"; the works are underneath it somewhere. In MY case the collar is secured directly to the console with a couple long screws; can't speak for yours.
If it's what it sounds like, once you removed the wheel, you see the shaft disappearing into a plastic trim piece. Once you remove the trim piece you'll be able to get at the bolts that hold the helm to the instrument panel. Remove the push/pull cable from the back side of the helm and it'll then all come out. On the Teleflex helms, a couple screws hold the plastic cover (I think they call it Bezel) in place. On one of our boats the heads of the little screws were rusted to where a phillips screwdriver wouldn't turn them. I drilled the heads off. But that melted the bezel at the screws...
