stell hull..help
loriedj
I have a 76 somerset houseboat ..steel hull that I purchased 2 years ago ...
well my hull is rusting from inside out (heavy rust)...I was approached by a fellow boater who said he will paint the inside (with paint he uses on bridges) and then he will fiberglass the inside to stop the rusting... will that work?
thanks Laurie
Yeah...if he builds you a complete fiberglass hull and all reinforcing structure. Otherwise, it's just a temporary patch.
Best to get the hull sounded before you invest any money. The hull could be paper thin in spots, especially in the keel and engine room areas. This is a significant safety issue. Best to cut out and replate weak areas. This is the #1 cause of scrapping steel hulled boats. In many cases cost of repairs exceeds the value of the boat. Many newbies are saddled with this problem when they get a "deal" on a boat and don't get a survey prior to purchase. This is a significant problem on Summerset, Drifter, RiverQueen, Sea Going and all other steel hulled boats.
Getting all bilge areas rust free prior to coating is a significant undertaking. IMHO epoxy over paint is iffy at best and a total disaster at worst. If any water gets between the epoxy and the steel it will come off in sheets. "Coal Tar" epoxy on a sandblasted surface provides good protection but is a big job.
Rustoleum on a blasted and primed surface holds up well when bilges are kept dry. I owned 5 steel hulled boats and kept the bilges dry (I was anal about it) and had zero problems.
A cheaper alternative (if the hull isn't too thin) is to remove as much rust as possible and use a rust converter coating. This needs to be followed up with a coat of rustoleum primer and a coat of rustoleum aluminum. Or whatever is your favorite brand of coating.
thanks for the addvice
....i have and out board motor...the crawl space (hull)is for water heater...fresh water ...ect. very thin in spots but will the paint and fiberglass work???
laurie
i'm no steel boat expert but i know that fiberglass will not work... rust will continue to grow under the glass. As OH said, some rust converters will work but you shoudl really have the hulled surveyed and plate thickness checked.
Chris Craft has a Roamer site with alot of knowledgable people on it. The Chris Craft Roamer was a steel hull and as they aged many had the same problem. Many were also repaired and still in service today. There's a boat-yard in Tonawanda New York (I don't know where you are as there is no Home-Port listed) that specializes in this type of repair and may be of some help to you. I'd try the Roamer Web-Site first and read....read.....read....read...Try to gain as much knowledge as you can before doing anything so that at least you'll be able to make an "informed" decision.
For expert advice go to metalboatsociety.com....register for the free forums and post there.
If you have enough plate left, the following will work.
Get a jug of rust converter and paint it on real thick. Come back the next day and the treated area will be black. With a scraper..putty knife..whatever...chip away the loose stuff.....and repeat. Do this about three times...or until you can't get anymore of the converted rust off. This may take a hammer and chisel. Then final coat with the converter again.
Next day....paint the area with Bar Rust 235...a two part epoxy coating by Devoe. Three nice coats will do.
The best way of course, would be to sandblast and then use the Bar Rust 235.
All of the above, and any other method, will be a wast of time if the good steel left is too thin.
Pascal may not be a steel boat expert....but he is dead right that fiberglass will NOT work.
Good luck
thanks again for all the advice..
the guy said he was getting the rust out first...painting it with epoxy paint he uses on steel bridges ....
than putting fiberglass on top....he is trying to convince me this will work...
It seems to me that if I remember right (and that's becoming questionable at my age) that repairs to the Roamer Hulls were done by in fact coating them with Fibreglass. I'm fairly certain that it's done on the OUTside of the hull though. Do you guys think it would make any difference being done that way? I can see the validity of your point about doing the Fibreglass work on the inside and trapping moisture/water etc. but wouldn't doing it from the outside in effect give it a Fibreglass Hull?
I'm not going to comment on the direction you should go with repair as I have never dealt with a steel hull boat directly. My advice is, if you think you have problems get another opinion or even two about what you need to do. The marina where my boat is located had 3 steel hull houseboats sink over the winter (and it's not that big of a marina) due to rust, leaks and neglect. Good luck.
Enough fiberglass on the outside should keep the water out even while the steel hull rusts away. Even if it doesn't stick, water pressure should hold it in place till you find someone else who wants a "cheap" boat. I'd start looking really soon.
You could do the same thing with a big blue tarp.
Yeahhhh! The problem is we don't know just how involved this rust is. If it is JUST surface rust on the inside of the boat, then removing it and covering to protect it is OK. The trouble with using acid to treat the rust(muriatic to eat it up and phosphoric acid to convert it) You have to deal with the deadly fumes. There's no reason you can't sand blast it. You have to get rid of the rust because once it starts and not completely gotten rid of, it will continue. Eventually, it would lift off paint.
Then you still have the problems of what might be coming in from the outside.
"Do you guys think it would make any difference being done that way? I can see the validity of your point about doing the Fibreglass work on the inside and trapping moisture/water etc. but wouldn't doing it from the outside in effect give it a Fibreglass Hull?"
no, because the glass would have to be thick enough and have enough support to provide some structural support. a few layers will not do that. As the steel keeps getting weaker the glass will eventually crack. it's even worst if you do it from the inside as rust will continue to spread and water will eventually seep in and find it's way, pushing the patch in.
The Structural strength (integrity) is more important than the Rust.
Fiberglass wont stay.
Knocking the rust off to bare metal, primer and paint will only fix that spot....for awhile!
If the Structural strength is comprimised (how you lak dat Yankee word?) fixing it with more steel is the ONLY logical answer.
Another source of information on that kind of stuff would be the steel Pipe line folks.
You need to reread what waveform said. Your best chance of stopping rust is by blasting to get rid of it and coating the steel with the proper marine epoxy. Interlux makes an excellent one as do some others.I have not tried the converters and will reserve my opinion on them. Waveform gave you two options and I concur with the second one.I am on my forth steel boat in forty years and know that properly primed steel last more than fifty years. Good luck with your project.
My Hunting partner tried the Converter on his Pickup Fenders.
It turned the rust to something hard and black. He knocked that off, put on more converter and repeated that three times.
When he got done he had a paper thin Fender with a rusted looking finish.
Primering that with whatever they recomended seemed to stop the rust.
Emphasis on the "paper thin"... Not a problem on a pickup fender, but I'd be concerned about it in the hull.
I think I'd have a surveyor determine how much steel was actually left, before proceeding.
