Stern in
Lots of good ideas here. I feel comfortable with the boat. With this dock set up and the wind it does make it harder.As I mentioned this boat is very flat bottomed, very little keel.
With dock mate on my port sticking out, by the time I go past him ( I am already turned stern in)and start reversing to get my stern in my boat is moving very quickly sideways,only 3' between us.I can not keep the bow from swinging to starboard.
Wind is never any fun while backing in to a slip, that being said, keeing the wind to your stern should aid in backing in. A wind off your bow is worse, it will push you around every time. Try practicing holding the boat still when backing against the wind to see how she reacts to your throttles, you should be able to power her in to your slip with the throttles, but don't hesitate using enough power to make the turn in to your slip, if you hesitate the wind will get ya every time. If you practice backing in to the wind, you should be able to control the boat until you need to make your critical turn or swing in to the slip. Practice makes perfect, do what I do, I don't care who's watching, If I think I'm gonna hit something, let the boat hit it, slowly, but learn from the bump, no one is perfect, I have seen seasoned Captains hit a dock or boat or two in the wind. After a while you will get used to it, keep mental notes on your position when making your turn so you can do it with your eyes closed. Good luck.
What's wrong with pivoting off the finger? Hang a fender sideways (that's why the hole goes all the way through them) and ride that bad oscar like it owes you money. It's sturdy enough (I'm guessing). Use a spring line as well to hold her.
Not a big fan of the "get it lined up, throw it in there, and throw lines on before it drifts off" methodology. I like 100% control 100% of the time. Ease it up to your finger, or the piling at the end of it, whatever the set up is (pictures would help here), keep a fender in there so you don't scuff your rubrails or hull (again, I don't know where the contact point is), and pivot on that BMF. (Big Mean Fender, of course - what's you think I meant?). If the wind is putting you to the finger, or even anywhere in that direction, you don't even really need the spring. Be gentle, go slow, and don't sweat it. The guys that barrel down between piers, whip the boat around and back down like a madman, throwing lines on and shouting orders to deckhands before the thing blows away, are the silly ones (ummm....sportfishers, maybe...). It's the guy that goes nice and slow and steady, has 100% control of the boat 100% of the time, and sometimes throws in the fake yawn, that I wouldn't worry about.
Forgot to mention - when you pivot, leave your wheel centered up. Split the engines, and leave them at clutch speed. If you start making headway or sternway, don't add power - take the other one OUT of gear for a moment. Even in boats with a lot of sail area, I've never needed more than clutch speed to pivot a boat in less than 30 knots of wind or 4 knots of current.
Mike , it sounds like you are too spoiled by those diesels and big thrust props, no offense. With my gas engines and 17"dia props, when it's a little breezy like this afternoon's 22kts my boat requires some judicial use of throttle between gear changes to swing the bow through the wind backing the "s" course into my slip. No prob at all but I'd never make it reasonably elegantly without some timely rpms to twist her. If little wind , idle is fine the whole way.
I AM a spoiled brat. But you do make a good point - some boats are underpowered or swinging small wheels and take a little bit more juice to bring them into the wind. But I'm sure we've all seen the folks that start getting nervous and add more power, then correct with more power, until you're surrounded in a blue haze watching sea turtles end-for-end in the prop wash (haven't seen that -particular- result yet, but I'm keeping my fingers crossed).
If your boat will move sideways that may be your solution. Shift to turn toward the dock but turn rudders opposite. Add throttle as required to balance. Some boats that can develop the proper balance between rudder and engine twist will move sideways. If your rudders are too small it may not work. try it away from the dock first.
