Stolen Dock Lines
In the know
Just back from the boat and somebody stole my dock lines.
They stole my lines and replaced them with these frayed crappy 1/4" lines.
Really bizarre.
Everything else was left alone.
wow. That is crazy. someone must be really short on cash!
We have a different problem on the dock I go to... there are more when you return than when you left. People just tie their own on anbd leave them???
A couple years ago I rigged my boat with extra lines before a storm. When I got back someone had stolen one set. Scumbags!
Those are the ones they steal from the other guys.
When I used to splice my own Halibut ground lines, I thought it might be cool to splice in a Red or Orange thread so I could spot my lines if somebody else was pulling them.
Maybe that might be a way to deter thieves. If those lines are indellibly marked the thieves might pass.
Heh heh but on the other hand, they might steal Pascal's, take them down to ITK's boat, make the swap and leave ITK's boat tied up with Pascals well marked lines.
Then sit over on your back deck and watch the fireworks.
Saw old lines on the docks all the time with my lockstitch or whippings, or another guy's lockstitch or whippings that I recognized. Don't remember ever giving away old lines, certainly never threw them away, though, but somehow the old ones always went away. Never really put much thought into it - and whenever I recognize the stitchwork on the splice nobody can ever remember where they got the line....
Originally posted by Thudpucker
The difference between Genious and Stupidity is that Genious has its limits.
Also "Genius" knows how to spell. :)
Well, maybe that's what he meant by "Genious has its limits"?:)
I think that was Albert Einstien, and he was a notoriously bad speller.
How about Dock lines with little bits of colored Rags stuffed between the threads. It might look kinda wooley but I bet they'd stay with the Slip.
I have the boats name on the lines, easy to ID....
I have one set of lines that stay at my dock and the “good looking” boat set that stays with the boat for travel
I had this problem at my last marina, and solved the issue by using wire ties on the lines at the cleats so that if someone wanted to take them they would have to clip the ties and not just untie the line. No way to say it was a mistake.
Since I have no cleats at my new marina/slip – just 4x4 stubs – I have run lines through the bottom of the dock and up around the stubs so if someone wants them they would have to get wet or cut the lines
I double up with the Boat set to the stubs if a storm is coming
Originally posted by abalmuth
...Since I have no cleats at my new marina/slip – just 4x4 stubs...
4X4 stubs to hold 50,000 pounds of boat. That takes bronze ones.....or EXTREMELY deep pockets.
Over the winter while my boat was in storage, someone broke into my boat through the side window and stole my dock lines, dinghy paddles, life preservers, binoculurs and a tackle bag. They left the hand held GPS, the portable fish finder, LCD screen tv, chart plotters,etc. It is really weird what people will steal!!
You feel my pain!
But it’s a 3-5 year wait for a slip in my town for a boat my size!
The slip is at a very small marina in front of the marina owners house and he kept his 48’ Searay sedan at this slip until he moved it to a yacht club- he did not want his boat where he worked!
With the lines run around the dock frame its much stronger than cleats, which I have pulled a few out in the past
He has two other marinas in the same harbor and if a big one is coming he will put me in the slings of the travel lift if he thinks its needed-
this is not to save my boat but to save his docks!
"I had this problem at my last marina, and solved the issue by using wire ties on the lines at the cleats so that if someone wanted to take them they would have to clip the ties and not just untie the line. No way to say it was a mistake."
That is a great idea - thanks.
I am still puzzled as to the why.
My boat is not nearest to the ramp, it is actually about half way down the finger pier.
The fact that all the electronics and fishing gear was left alone also remains a mystery.
I know the local lobster fleet will insert razor blades into their lines to deter locals from hauling their pots, but I thought that would be a bit extreme and dangerous for dock lines :)
Originally posted by In the know
[i}
these tend to work but get messy & you well have to rewax the boat
I've met a couple folks who DYED their nylon dock lines with ordinary RIT.
[i}
I haven't seen one of those since 1968. Brings back some memories, not all of them pleasant.
Dan
Hopefully you were setting them and not disarming them
Ugly weapon, took a lot of lives, saved a lot too
are you sure your dock mates aren't pulling your chain ?
