Storing Canvas
ajschwab
Is it OK to store my canvas, it has eisenglass, rolled up over the winter? I have been laying it flat but it uses up most of the floor space in the attic and the Admiral says the space can be better used.
Roll it loose and clean with a clean towell inside so the glass is not stored on itself. Put in a cool dry place where there are no mice.
Hang it up! Maybe that's too obvious but it keeps the vinyl flat without any pressure on it and the mice won't crawl in to nest.
I kept mine along the garage wall.
It would be nice to hang it up, but not everyone has room in the garage, or a garage at all. Such as myself. Although I'm having one built starting on Monday. Yippee! [:-bonc01]
I store mine loosely rolled up with clean soft cotton sheets between each panel. I took some old 100% cotton sheets my wife was tossing out and cut them up to fit each panel. Then I put the canvas in the storage bag and put it up int the attic. The bimini, with the top on the frame and the boot installed, hung in my in-law's garage.
Keep an eye out at the home store for linens on sale. Pick up a set of WHITE flannel sheets. Don't get ones with a pattern or color as that WILL transfer onto the clean vinyl (voice of experience...) Cut them up to fit the panels. Then get a couple of left-over cardboard tubes from a fabric shop. Lay the panels on the fabric and roll 'em up on the tubes. I usually roll up like panels together (port/starboard forward, aft, three forward panels, etc).
Mine fit neatly into a second-hand sail bag I picked up from Bacon's in Annapolis. But if the panels aren't too long you could probably get by with a large duffel bag. This way they're protected from rubbing or getting creased from folding. The duffel bag also makes it convenient to move the bag around in the cabin. It does help to put a seam around the edges to keep threads from pulling loose.
It's true that the fabric would make a fine home for mice, but if you have mice in your house you have bigger problems. The money it costs to get rid of them would certainly be a lot less than buying new sets of canvas.
I like storing mine flat with well used flannel sheets between them. I also had a problem of where to store them. Since I have an unfinished room in my basement used as a workshop, I lay the panels on a sheet of plywood connected to 4 pulleys. I pull it up close to the ceiling and walk under it all winter.
I hung a 4" PVC pipe from the rafters. Drape each panel over with a plain flannel sheet between. I always clean & wax isenglas before hand. Keeps everything neat & dry.
I store mine flat between the mattress and boxspring of my guest room bed. They stay clean and are protected from sun, air pollutants, mice, etc. In October I'll take down my screens and reinstall my isinglass panels for the winter. After I wash the screens and let them dry, they will go under the mattress for the winter.
