storing propane bottles
greenstreak
Does anybody store their propane bottles on the boat? I have a magna grill and was thinking about storing the bottles at the back of the boat. I have a storage compartment back there. What is the thoughts of doing this?
Art
Propane bottles should be stored in a vented locker where the vent goes overboard. Is your boat gas or deisel powered?
We keep ours below in the cabin mainly to keep them out of the heat.
billy--I have a gas engine. My storage is at the stern area of the boat. It is above deck. It is where my rear seat folds into. So the bottles would not be in direct sunlight.
thanks
art
I store mine in the transom locker. Never had any problems
Assuming you mean the smaller tanks; I have a small bag made by Magma that hangs in the cockpit that holds three of them. I attached it under the cockpit ladder.
Propane is a liquid that is stored under pressure. When it is released in it's gas state it is heavier than air and will settle at a low point. For that reason, bottles must be stored upright an in a vented locker that where the vents are low and allows any escaping gas to go overboard and definitely not into a bilge area. For all these reasons storing propane in the cabin area is not a good idea.
i use a pvc pipe (can't remember what diameter)that i cut to hold 2 propane canisters. i put a cap on each end of the pvc tube. the canisters are very snug inside and if there is a leak, it would (hopefully) stay in the tube.
I store mine in a step box in the cockpit but I have also used the canvas storage bag sold by Magma.
You have made a nice bomb, it's a terrible idea on land even worse at sea.
I've been wondering the same thing. Now that I've read the comments, I think I'll put mine in my fish locker. It has drain going outside the boat and I'm a very good fisherman so that should not be a problem.
I do the same, but I have drilled 1/4 vent holes around the pipe. I guess if you bought the drainage PVC you wouldn't have the trouble of drilling the holes.
If my memory serves me right, ABYC states cylinders are not to be stored in an enclosed space.
Maybe I'll go with my first idea and keep them on the bridge under the dash.
Okay...where should the small propane tanks be stored on the boat?
I kept mine in a canvas bag that I hung in the transom locker. That locker was well ventilated and had two drains that that emptied directly overboard.
How about a dock box? Then just take it with you when you leave?
I store one or two in my built in ice box at the galley. This box is vented overboard, intended to drain water from the melting ice overboard instead of into the bilge. And the door has a full gasket, so nothing will leak into the cabin. But if I don't need the propane, I leave the canisters in the dock box.
I keep them in a vented dock box. Never in the cabin. Never ever.
The small bottles are very prone to leakage, especially once they have been used. Propane is about the most dangerous thing you can bring aboard your vessel. Three years ago, my FIL and I watched a guy try to put his 35 foot houseboat back together after it had been separated at the hull deck joint by a propane explosion. Unbelievable force of that explosion.
The cool science thing about those little dinky propane canisters is that because the gas is held under pressure, even a small propane canister holds quite a few cubic feet of gas when leaking. There is a lot of explosive force in one of those things.
bp
