Stripping Bottom Paint
vv1212w
We have a 30' fresh water Sea Ray Weekender with way to many coats of bottom paint. Plan to strip it and not looking forward to it by any means. Interlux Interstrip 299E was suggested by West Marine. Does anyone have experience with this product. Thanks in advance for any comments.
St Clair Shores, MI
I have the same boat in across the lake from you in Wisconsin...a 1986 sea ray 300 wekender and will be doing the same thing as you very very soon. I look forward to seeing the opinions that post on this topic...
Fellas, theres no easy to do this job,for what you will spend on Interlux,hire somebody to sand..sand...sand.
Actually, there is an easy way - Sodablast
If Money is easier to come by than your time - PAY THE MONEY FOR SODABLASTING!!!!!!!!!!!!! It saves the gel coat, but strips the paint, leaving your surface rough / ready to startover.
If not, get ready for what will be the most miserable job you've attempted in your life.
I used the product to strip two layers off a 268 Sundancer about 10 years ago. I was pretty successful with it. Nearly all of the paint came off with the stripper and then I did a final clean up with acetone. Follow the instructions carefully. I remember that it would start to affect the gelcoat if it was left on too long. The stuff is very messy and caustic, especially working under the hull. The stripper blisters the paint and then you need to scrape the paint off with a plastic putty knife and then rinse. Most areas required two applications. Clothing and equipment to protect skin, eyes, etc. are required. I did the job in the spring in Michigan and found warmer temperatures were definately helpful to promote the chemical reaction. It probably isn't something I'd be real anxious to do again but the results were good. I believe a little under 3 gallons did my 27' boat.
