Swim platform refinishing
Britanic
I have a solid flat fiberglass swim platform that is looking pretty shabby. The gelcoat has many hairline and thicker cracks in half moon shapes in several areas (from other owners hitting pillings).
Any suggestions on how to easily repair, or a good source for a replacement?
I have access to an industrial spray booth and was thinking about just reshooting it with paint.
The thing is structual damage to the underlying glass. If you feel there's no such damage or you will never use it in a way that requires it's full strength, THEN Gelcoating or painting would be your options.
Check books on fiberglass repair.
Yes, platform is solid (no structural damage)Its a bolt on platform with a stainless brackets underneath.
There's a lot of prep work on FG, especially if it's been waxed. Any fiberglass repair book will tell you the procedures for refinishing.
Depending on where the damage is located, if its just on the non-skid part, I would use the spray in bedliner on that part. They can spray it any color you want, it is not slippery when wet, and holds up great. If the damage is in other areas, I would fill any nicks and then gelcoat it. I refinished the gelcoat in several areas of my boat. The hardest part for me was finding the right amount of hardener so the gel would not stay "gummy or soft" days later. I ended up mixing it at about 4 times the recommended strength. I sprayed the dash area, the dinette table that I made, and the intake scoops. I brushed the anchor locker and the bilge.
Ken
Can you cover it with the flexiteek or some other product?
That would look pretty sharp and the cost to just do the swim platform is not bad.
I know a guy who removed his bolt on swim platform to rework it. Found water pouring out of the bolt holes in the transom. Ended up having to have a new transom due to extensive water damage. I guess his wanting to beautify his swim platform helped him find a major problem, but it cost a lot more money and time then he had planned!!!!
Yup:
depending on the current condition, it could take lots of man hours to refinish if you re-gel coat....grinding, fairing, etc.
i'm assuming the cracks are on the edges and not just top side? any chance a soft, grip pad would cover it up enough? something like this...
http://airjunky.com/traxxed/
If it doesn't have to look perfect, just paint it with a two part poly.
If you want it to look like new you'll need to grind or groove out the cracks with something like a Dremel tool or an old school beer can opener, fill them, prime and paint.
Thanks guys. THe boat is 20 years old but in great shape. It does not have to look perfect. Becasue the cracks are not very large I think I will go with the two part poly paint. I am going to look more into this airjunky foam pad. I think thats some cool stuff and is pretty cheap. I will post back with what I end up with.
