- Jan 20, 2002
- 7269
- 802
I need to redo the swim platform on my 85 Carver Mariner. Where the support braces attach to the outside edge, they are through bolted and after 24 yrs, water has apparently gotten into around the castle bolts. I plan on removing the bolts and either cutting a 2-3" rectangular hole on the top fiberglass layer, digging out the rotted coring and filling in the void with fiberglass-or using an allen wrench chucked into a drill and roto rootering the damaged coring and filling with a fiberglass and epoxy mixture. Then I started wondering if what is used to fill the void needs to be mechanically connected to the good coring in order to make a good structural repair. Am I over engineering this repair? There are 4-5 braces at the outside edge of the platform in varying degrees of water intrusion. Any and all dvice is appreciated.
