Switching from Float to Fixed Docks.
Northern Ivy
Greetings our current slip is at a marina that has floating docks. We are taking a second slip at a local marina that only has fixed docks. The arrangement is a full length fixed dock on the port side. Tow pilings for the bow; and a fixed pier along the stern. The tidal range in our areas is around 5-6'.
I know that I have come across a few good threads on ATC regarding the strategy for tying lines to a fixed dock, but I can't put my finger on them right now.
I would love some pointers on any changes in strategy that are needed between floating and fixed.
Assuming you're stern in: Cross the stern lines, use spring lines from forward piling to midship cleat (to prevent the boat from hitting stern against dock), and use a bow line on each side to the piling. Leave enough slack for the tidal change, but it may take a few adjustments to get it just right.
Generally, the crossed stern lines are enough to keep the boat from surging forward much, but in stronger blows, you might want springs going from the dock to your midship cleats as well.
Yep, I second what JoeBTB said. I have been on fixed pilings for years. One trick is to mark your lines after you have figured out all the tidal change and adjustments. That way, when you go out and leave your lines on the dock, you tie up to the marks you made and that is all there is to it. I use a wire tie to mark my tie off points on my lines.
I concur with everything stated above, but from experience I can tell you to make sure you mark the lines. I like you are doing made the move from floating to fixed dock and did like they state above. But when I had everything set the way I needed it I didn't mark the lines and the first time I went out I had to guess on where things should be when I came back in. When I had them set again I MARKED THEM. So be sure to follow that advice and mark your lines.
I spent the last few years in a fixed dock with a 2-3 foot tidal range and may be able to lend a hand. The following is from personal experience and worked well for me as I refined the procedure over time. The boat at the time was a 2001, Regal 2460 with an extended swim platform.
There are a lot more ways to skin this cat than I am about to describe. I went for coat savings. OK, I'm cheap.
First, you are going to need a ladder or stairs depending on the setup either attached to the boat or the dock.
Hopefully, the security in the marina is good as you should plan on back splicing the lines to the dock cleats and leaving the lines permanently attached to the dock and pilings.. Bring another set to travel with. It costs a bit more, but it just makes life so much easier when you pull in and everything is right there. I found there are two ways to tie the stern. Either the stern lines are always crossed and left long enough to secure the boat at mean low tide if you get in from the side of the boat, or (in your case) the starboard side uses a weighted line at 45* off the starboard quarter. A line from the port dock to the rear port cleat secures the port side leaving access to the stern if you board from a platform as I did. Crossing the stern lines and climbing on a platform is courting disaster. The bow lines are tied to the pilings port to port and starboard to starboard. I do not know how big your boat is, but anything less than a 12" piling will snap like a toothpick with a boat of any size at all using it as a pivot when you pull in. I could flex an 8" piling (what was at my former marina) with my 2460. Just something to think about. I used two ways to approach the tying of the bow lines. One is to leave them long enough to get just barely taught at mean low tide and the other is to weight them. I prefer the weights. They are cheap, easily built, and replicate the action of a "tide slide" or mooring whips. In addition, with the weights, once you get the lines set, the boat is held away from the dock in all but a heavy wind off your starboard side. All you do to board is pull on a line to get her close enough to step on.
Affix a couple or three fenders on the dock to protect the hull. It will actually be cheaper than launching and retracting fenders each time you are there as you will have to rig at least two fenders per line to accommodate for the tide.
I would be happy to go into detail regarding the weights should you desire to go that route.
Good Luck.
HTH
Also, keep in mind that unless the lines are well used they may stretch. I would not mark the lines until you have been through a couple of days of tide changes. Even after that if you get a good blow the lines may stretch even more. My spring line from the piling stretched in a hard blow and almost had the stern under the pier. Now that they have had quite a pull on them they are marked.
good advice so far...
the spring lines are the critical lines as they're the one keeping the boat from hitting the dock. they're the first one you will tied when coming back. being normally fairly long (from bow piling to midship cleat) they can be adjusted so that the boat is fairly close from the dock yet safe.
for the spring lines, you can use the eye on the boat cleat since you will put them on when they are slack, before the boat is all the way in. this way you dont' have to worry about marking them and maybe putting them on wrong and hitting the dock. For bow and stern, you're better off using the bitter end and marking that, I use nylon wire ties placed at the spot the line cross over the rub rail. using he bitted end allows you to adjust the lines when needed and gives you more leverage to work the lines (critical on a larger boat).
crossing stern lines is ideal by may get in the way of boarding. if you can, you may be able to tie you stern lines to cleats outside the slips, that gives you an angle and doens't interfere. check with you neighbors first though.
I'd echo especially three of the above comments:
- Get a second set of lines for transient use, and leave your permanent lines there when you leave the slip.
- Mark your permanent lines.
- Set your spring lines on the midship cleats first when docking.
On a floating dock your fenders can be attached to the dock as needed regardless of the tide. On a fixed dock you'll have better protection as the tide changes, with the fenders attached to the boat
Thanks everyone for the feedback. I am planning on a six line setup and I set on four of the six lines. It appears that everyone at the marina has bitter end of the line tide to pilings (bow & spring). And for the two stern lines they seem to be crossed withe the bitter end running through a pulley attached to a concrete block.
I have never used a pulley setup but my understanding is that these pulleys are going to take the slack out of the bow and spring lines at high tide and allow the required slack at low tide; while at the same time (assuming that the lines are set right) keep the boat centered in the slip.
I would love if anyone could share the details of the system that you use for the pulley system for the stern lines?
Lookup tideslide.com
I saw them at the Channel Club being used on a large 65 footer and they seemed to work very well. Owner swore by them.
Jonathan
"On a floating dock your fenders can be attached to the dock as needed regardless of the tide. On a fixed dock you'll have better protection as the tide changes, with the fenders attached to the boat"
fenders are near useless with pilings, unless you use fender boards and they are not needed anyway if you have set your lines right. I've been in fixed dock slips for 15 years now and never used fenders...
not sure i see the point of pulleys and weights... if your lines are set correctly, you get have the boat within inches of the dock and it will not hit. although, obviously, you're better off keeping a couple of feet gap, which you can still easily step across.
fenders are near useless with pilings, unless you use fender boards...
A fender tied to the boat horizontally is near useless???
I mark my dock lines with a little peice of black electrical tape, then once tied up I will push the boat side to side to make sure nothing hits the boat, and also check forward and rear spring lines. I would also go back the same day during the tidal changes and check the lines until you find a happy medium to set your lines. I too use the bitter end to tie off on to the boat, makes for easy adjustments, just line up your black tape and tie off. I would also ask some of the other boaters at your dock for there opinions on how they tie there boats, I did that at my marina, and learned a few tricks to boot!
most the time the fender gets pushed aside even when set horizontally or the boat moves fore and aft just enough to squeeze it aside. With properly adjusted lines, the boat should not contact the pilings except when coming in and out, and that what rub rail are called rub rails :-)
That depends on the dock and how the boat fits in the slip. Many do not allow a proper tie up so the boat will touch a piling, and more so, depending on the weather. In that case a properly tied fender horizontally can do wonders for a boat and save the rub rail when the weather causes it to do more than rub.
The same with a side tie too.
So we moved the boat to its new home yesterday. She is sitting pretty in her new slip; we were on the boat for a full tide cycle so the lines look good. The new marina is eliminates nearly 50 mins of no wake puttering about to get to the ocean so we are very excited. The facilities are an improvement; and the $80 a foot cheaper will buy a lot of diesel.
The people seem really great; there were a ton of folks there when we left around 10:30 (we would have been he only people at out old marina). And the good news is that I must have passed my docking test; as everyone was watching as the "new boat" was backing down.
dave, true but unless the slip is so narrow that you dont' have at least a foot on each side, you can center the boat and it will not touch the pilings. I have about 15" on each side and the boat never rubs even in strong winds.
if you're tied alongside, you have no choice. the downside of fenders in addition to them moving around is that in the long run they rub too much on the boat. i've seen a few boats here getting damaged because the owners relied on fenders instead of properly tying the boat in the slip.
Pascal is correct on this Dave. I have never used fenders while in my slip. The lines are tied so that my boat will never hit the dock and I leave the lines permanently at the dock when I leave. Upon returning I hook up the spring lines first and then the rest of them.
I'm in a 30 ft floating slip, my little 22 ft boat has lots of room. I center my boat using lines I always leave attached to the dock. I also have fenders I leave at the dock. One time a ring at the dock broke free and my boat, pushed by wind and waves, rubbed against a nail all week. Had to have the hole repaired. That is when I learned I needed to have fenders available just in case.
When I arrive at the boat, I release the lines on the starboard side and retie the port side lines so that the boat is along side. This makes it easy for me to climb on and off.
