Tank Tender
bally79
I have read all the data about the Tank Tender on their website and was wondering if anyone here has used the product and what their feelings are about it. Also, is it as easy to install as they claim?
I installed it last summer on my Tiara. It is easy to install and is the best monitoring system I have ever owned in 40 years of boating. It is old technology, has just one moving part and requires service every 15 years which is easy to do. The readings are very precise and Tiara is thinking of using them. They are a little pricey but I save $30 a month on pump outs because I know exactly how full my waste tank is with the push of a button (the 1moving part). They use no electricity and work off of air pressure.
Just got on the web site and I like the simplicity. I do have to say, for something so simple and without electronics, the price seems rather high.
The Tank Tenda will work on water, fuel and engine oil for which it is excellent.
It will not work on Black Water for very long. It gums up.
Been there.
Been there.
If by Black Water you mean sewage in a waste holding tanking, gumming up has not been an issue for us. It was designed for holding tanks and works great.
This monitor is a little pricey, but the display is high quality and looks expensive.
If you saw my post-- I was asking the same question. Based on feedback and research, I'm sold on the Raritan system. It's non-invasive to the tank(s) and I have not heard of any complaints from anyone who has the system in use. I just need one for fresh and waste water tanks. It comes with two sensors and the one panel which accomodates up to 4 tanks.
Paul
Yes. Black water = sewage. The small hole in the end of the tube would plug up easily and repeatedly in the installation I had in the holding tank of a 3818. Maybe there was something else of which I was not aware.
Might be an installation issue. I helped the tech install this unit on my boat. He mentioned the need to install the tube 1" up from the bottom of the tank to keep the tube clear. When you take a reading, the plunger clears any debris in the tube. I can see a possible issue if the tube was on the bottom of the tank and you put the boat away with a dirty tank and things dried out. So far, we have had no problems and the device functions as advertised.
I have a tank tender in my older Hatteras. It's plumbed to the forward fuel tank, the fresh water tank, and the holding tank.
I have no idea how long it's been on the boat, but my guess is a LONG time. It works just fine.
Glad to hear it works in black water. At least some black water.
Perhaps mine was too high off the bottom to where the open end of the "sensor" would have to poke through the surface scum as the tank refilled from being emptied.
Walstrom's Marina in Harbor Springs, MI put me on to Tank Tender. According to the tech, the only thing they replace is the tiny O ring at the top of the tank that sometimes drys out after 15 + years. Replacing it is as simple as unscrewing the compression fitting and removing/replacing the part. This is about a 5 minute job. Walstrom has installed a number of these as the definative fix for the notorius Tiara holding tank sensor.
