Teak deck upkeep
Ductboy
I have cleaned teak decks before, but I am sure I probably did more damage than good. i have been looking at used boats for about a month now and have come across several that had teak decks. Some look as though the owner or yard scrubbed them too agressively and the grain has become raised. Some of the cualk joints also have become elevated to alevel above the top of the teak plank and would need to be shaved down.
My question is this, what is the safe, proper method of cleaning a teak deck without raiding te grain and lengthening the life of the deck for as long as possible?. I only want to clean, I do not want to oil them.
Dan
Use sudsy ammonia & TSP & NEVER scrub with the grain, only across it. Actually I don't use a brush. I use those nylon scrub pads.
Al
While ammonia and TSP will clean the wood, they will also darken it unless you follow up with an acid wash to react with the ammonia/TSP combo bleach out the teak.
This, as is most any two part cleaner, is to harsh for everyday use. For that I would use Spic and Span or Oxalic acid crystals. Sometimes sold as "wood bleach".
And like Al mentioed, use a Doodlebug pad and scrub across the grain as much as possible.
Sand it down till its smooth and clean. Use
Sikkens Cetol. Follow the directions and it will last you the season or more. Then you wont have to contend with the cleaning all the time!
Cetol on teak decks (IMHO) just makes them slippery when wet, very hot in the sun and a PITA when it comes time to remove it.
All the teak on my boat, inside & out, EXCEPT the deck is done with Cetol. IMHO, Cetol on a deck is the worst thing you can do to it. Especially after sanding the teak "smooth & clean".
Al
I don't know much about teak decks [except I love them when they look good!!!], but I have a friend who uses nothing but that red transmission fluid on his. They look gorgeous and are not too slippery. Go figure!
