I've had 25 years as an a/c, refrigeration and commercial appliance tech and have much experience with both tape and paste. If you use the tape and start it - as suggested above - 1 or 2 threads from the end, you'll be fine for the 1st season. When you pull it out, tho', it'll leave little threads of tape stuck into the deeper threads. When you screw the new component in, it'll push those threads into the cavity and they can plug metered orifices. If you pull a component that was installed with tape, shine a light in there and take a look - you'll see those little teflon threads. You'll want to spend as much time and effort as is needed to get "all" of those teflon threads out. A tiny thread can cause a huge problem - usually at the worst possible time.
Teflon paste will lubricate the threads, too, making the component easier to get out. You'll seldom see the old hard setting sealers anymore. Either tape or paste will be cut by the pressure of the threads and you'll have metal to metal contact and both will read OK on an ohmeter....always did for me anyway. I've tried it with no sealer, since - as mentioned above - it is a tapered thread and had uneven results. Sometimes it works, others not. The threads have to be perfect for that to work. Use the paste.
If a component is really in there tight, heat the end of it with a torch (not always possible or recommended) and get it as hot as possible. Heat only the component...then wait for it to cool off before putting pressure on it. The heat apparently "cooks" the sealer and often it'll come out more easily. If there's plenty of metal around it, heat the metal fast with a good torch and put pressure on it immediately, before the component heats up and expands. Often the housing will expand, allowing easier removal of the component. Every situation is different.
Tighten the component till it's good and snug - you don't have to put a cheater pipe on it and reef it to 500 lb/ft. Take it easy. If you do get a drip, tighten it a bit more. If it still leaks, pull it and re-coat it with paste and try again. Easy does it.
Many manufacturers of commercial kitchen equipment will void warranties if they find that someone has used teflon tape in their product. After a lot of experience with both, I rarely use teflon tape anymore.
Hope all this helps.
Lar.
