This is a start, I think the BoatFix technical pages have some of this testing too.
http://www.downloadingfiles.co.uk/teleflexfiles/gauges/Inboards,%20I-O's.pdf
Bob's thermostat point is related. Since we hopefully don't boat in water above 120* or so, if the engine thermostat is stuck open, the gauge will continue to read cold, all day.
Personal experience: I went to the dry stack with a friend to fix his temp gauge. Marina parts dept said it's probably the thermostat, and it was.
I think if you leave the key on, remove the single wire from the temp gauge sender and ground it, the gauge will swing all the way from Cold to Hot. That'll confirm the dash gauge, if the rest of its wiring is OK. Then it's sender failing to respond, or thermostat stuck open.
