We have thick foam, with a reflective "foil" on it. Recently it has fell down in a couple of places. After 20 years ... why now?
Today I looked it over and found the thick foam (about 1 to 1.5 inches thick) has a layer of heavy duty rubber inside it. I sprayed a high quality spray glue on it (3M) and it did not stick. I have some thin steel with holes in it, so I used wood screws to hold it in place.
In another spot I used decking type screws to hold it in place.
1. Any idea why this foam would just start falling off? I have not been well enough to take it out for a log run since Oct 2004. I know I have asked a couple of "off the wall" type questions...thanks so much for your patience. Any ideas on why the foam is just now "falling off" or what you would use to hold it on?
