Three rescued, one missing
Riverbed
Another commercial fishing boat has gone down off the Massachusetts coast. Must have happened fast as they weren't able to get life jackets on but managed to activate a beacon. Dangerous job, fishing.
http://www.necn.com/Boston/New-Engl...sing-off-Massachusetts-coast-/1226628330.html
Farther to the north, a Newburyport, Massachusetts bridge was struck by a passing barge. Not a good day to be in or around Massachusetts waters. Wonder what's next...
http://www.boston.com/news/local/breaking_news/2008/11/traffic_diverte.html
EPIRBS on commercial F/V's are required to be self-activated and stowed in automatic, float-free brackets by the CFVSA.
Proof positive it's a solid requirement.
Do you have to deal with Whales over on the least coast?
They were a real problem when I had my Halibut lines out in Cook Inlet AK.
They'd go down somewhere and you'd never know they were around till they surfaced. Sometimes right at the boat, and sometimes caught in my line.
I kept knives on magnets all around the back of the boat in case we had to cut the line and let a whale go.
If you couldnt cut yourself loose in time that big blubbering bully would take you right over sideways.
Something like that might explain why they didn't have time for the PFD's.
On the other hand, dont they wear Float Coats while handling the nets?
May be that they hung up and tripped, may be that they took on water so fast it went right over (would have to be a pretty serious ingress), I'm sure the newspapers will publish it as soon as anything is known.
While I was in AK, in almost every maritime place there are photos of the older Hand seiners.
The nets were drawn up out of the water over a big pully rigged up on a mast about 20 feet above the deck.
More than one photo showed the boat capsizing because the net had way too many Salmon for the boat to maintain upright with that weight pulling to boat over to the net side.
One photo showed two boats along side and the crew with pitch forks throwing Salmon out of the net and into the other two boats.
These missing guys might have been picking Cod from the net, and something snapped. The net, Crew and Cod all went overboard.
Like Charlie says, we'll have to wait on the Maritime Board's report.
A few years ago a well known fisherman in these parts, drown when(speculation) their anchovy net caught on the bottom as a wave hit and rolled the boat. These were guys that literally had over 100 years of fishing between the 3 of them.(two of them had over 100 years)
It's a very dangerous business and the sea has no favorites.
