BoatBumGirl
- Jun 4, 2007
- 26617
- 18
Hello Forum!
Just getting my '90 Searay ready for the water; and noticed that the trim switch on the throttle will not work in the "up" position, but will work in the "down" position, and the "trailer" button allows the lower unit to rise.
In other words, the unit is allowing the lower unit to go up and down, but will not allow it to go up with the toggle-trim switch located on the throttle handle.
Is it the whole unit? Or is it just a loose connection...or perhaps the "up solenoid"??
My local Yard just quoted me $560.00 to replace the Tilt/Trim Sending unit.
Plus, I filled the reservoir with fluid and when I used the switch, it overflowed.
Houston, we have a problem.
PLEASE help guys, I need a hand here.......what should I do?
thanks so much,
BoatBumGirl
thanks so much,
BoatBumGirl
