Tool Set
Good one, adru, got one of those too but use the tripod 20x as much. I bump into stuff with my big head, but there are definitely times when those head lamps are invaluable. I use an led work light wand a lot too. Slides into places other things don't fit into and casts a bigger light than a flash. Actually I have a slew of lighting devices each of which has come in handy at one time or another.
David, I guess my original point was before I got carried away, which I am about to do again, is that while I have one of those big sets, I hardly ever use it. That little 8 piece ratchet or "gear" wrench set really is handy, plus a handful of others in odd sizes.
All the stuff I have listed (plus most of what I am about to list) could fit into a normal size tool box if need be, with plenty of room for other stuff. I have the luxury of a fair amount of space, so I can segment stuff into various drawers and plastic tubs around the boat.
Bill's 90 degree drill/screw driver is a handy item. So is a Dremel, but I haven't got to that yet so it must not be necessary. Since we are on a roll here, let me add some of the secondary, but darn-necessary-when-you-need- them items (that is, not used everyday, but non-optional) A lot of this stuff, with a couple of exceptions, Harbor Freight quality is all you need:
One of those infrared/laser thermometers (actually I use this all the time when doing ER checks). A small vice. An assortment of files, especially rat's tail and half moon. A good tape measure. Hose cutter. Mini and regular sized hack saw. Scissors. A couple sizes of vice grips and channel locks. The best serrated folding knife you can afford, preferably with a marlinspike on one side. Tweezers. Grease gun. Bicycle pump with needle for inflating fenders and pumping up other stuff you didn't think of, such as steering and engine control hydraulic reservoirs. Flair wrenches that fit your fuel and hydraulic fittings on board. Battery terminal extractor. Impeller removal tool. Hand held mini sledge hammer. Copper and synthetic stiff brushes. Many flavors of sand paper. One of those paint scraper/putty knife thingies with the hook cut into one side. Big towels that can be sacrificed. A long funnel and a short one. If you have wet cell batteries, one of those battery fillers that NAPA sells (I have a bunch, so that item probably belongs in my first list). Then there are all the pastes, liquids, tapes and other not-hard stuff, that's another thread as are spare parts.
OK that completes my short list, that fills out the 80-20 rule. i.e. the 20% of the stuff that does at least 80% of the work. More like 98% in my case. There are a bunch of things I didn't list because I rarely if ever use them and something else will get you by. I am not particularly handy, I just want to keep the boat going and floating and the crew happy. I am not a tool nut or the kind of guy that can tear down a diesel engine and put it back together. In fact, I am kind of a klutz. If I can save a few hundred bucks by not having to hire someone to do something simple, so much the better, but a lot of the places we go that someone isn't right around the corner anyway.
George
I should have given more details when I started the thread. I have a 26 footer and boat on a dammed river. I was not looking to carry tools to rebuild the engine. I purchased plenty of tools from Harbor Freight: drills, saws, mig welder, engine jack, pry bars, etc. Most of those items are used very little. The last time I was there I did not see a decent tool set. For the most part their mechanics tools are OK. My knuckles would tell me to be a little cautious if I was working with trying to break a frozen nut/bolt. I tend to start drinking after the work is nearly completed which lessen the chance of dropping the tools overboard.
I do have some cheap screwdrivers, wrenches, socket set, and other tools. I keep bailing wire, ty-raps, screws, bolts, electrical tape, rubber tape, couple coils of #8 copper wire and smaller wire on the boat. I have used the #8 wire (appx 20'in length) to jump start other boats on a few occassions. Hook them up to the other boat and recharge their battery for five minutes or so prior to starting.
Now ya tell us. Glad I did not go into details about my inventory :-0
Looks to me like you have almost all the tools you need. I would add two more.....
# 1 Subscription to Boated "for full access to some knowledgeable people"
# 2 Join up to BoatUS or some other tow service " for when all the tools and knowledge don't work"
There is a tiny difference for someone who has a smaller boat that can swim to shore versus someone who has 40 plus foot boat that is off shore. I always get a chuckle out the guys who carry the 5'x'4'x'2' foot tool chest along with a machine shop in the engine room. I don't even carry a spare impeller or fuel seperator. If something happens, and it did once, I just get someone to tow me a mile back to the dock and put the boat back on the trailer. :-)
Out of the 40 lbs or so of tools aboard my 27'er (lot of offshore play), the tool I use more than any of the others BY FAR is the 10 in 1 screwdriver/nutdriver such as the one made by Klein Tools. Besides the so-handy collection of bits, the nut-driving shafts are just the right 2 sizes for my very frequent checking tightness of most of the hose clamps onboard, except for a couple metric head ones that need the bits or metric socket, as well as for plenty of other small hex head fasteners.
Here are a couple basic case-sets at BoatFix: http://www.boatfix.com/catalog/332.pdf but those may not be the very highest quality.
Since it sounds like you are looking for something a little more extensive, FWIW, Sears presently has a nice 154pc socket & combination wrench set on sale 1/3 off for $99 that you could add some other wanted tools to to fill out. You could relace the metric tools with those, but I'd keep metric onboard. If that's too extensive , buying separate wrench/ socket/ driver/ pliers/electrical sets of just what you have in mind and keeping them in one toolbox or cabinet drawer onboard may be the ticket.
Unfortunately, everyone has a different idea of the "essentials."
Well then buy that 8 piece set of gear wrenches I started off with, one ratcheting screw driver with bits, a cheap stripper/crimper, a vice grip, all at Harbor Freight and the BoaterEd Anchor I mentioned so you can read George van P's article! Or why buy anything at all? Just swim to shore or walk the dock and borrow whatever you need. But don't come complaining here when you get stuck somewhere!
My tool chest is 2' x 10" x 10", BTW.
You're welcome!
You're welcome!
Where can I find a racheting screwdriver? I had an Allied that had a joint in it that allowed it to be angled at several different degrees. The racheting mechanism went toes up and I haven't been able to locate a new one.
TIA
Sams club carries a kit by channel lock has most of what you would need in a decent case i think they were 50 bucks
I've seen those. What is the quality?
I've had one of these in the tool box on my truck for years, no problems.
i have 4 kits and have had no problems other than light rust when one kit got wet. one kit even survives in the poker run boat(bungee netted to the floor). i like how the sockets and wrenches stay put when open upside down or tipped over.the 1/2 socket set is pretty strong surviving a pipe extension for more leverage.....sometimes you just have to resort to McGiverism
