towing PWC
cpro
Does anyone tow a 4 stroke PWC? We have a Yamaha 4 stroke. Owners manual says dont. Would like to tow back to the marina after dark at slow speeds. thanks.
I can't answer your question. Sorry.
But I DO have a question:
You state, "Owners manual says dont.". Ok. So what are you supposed to do if ( when ) you break down on the water? Sink it?
Get yourself a hose pinch pliers from Sears like these.
00947051000-1
Use the plier to pinch off the cooling intake hose to the engine and you can tow it all day long. I don't recommend high speeds for stablility reasons.
if you cap the exhaust securely as well as the water intake from the drive along with the air intake on the motor you should be able to tow it at slow speed. best advice is to bring it back on board the boat or drive it home.
I towed my 2007 seadoo gti jetski all the time behind our silverton and never clamped any hoses and never had a problem, including going up to around 18 knots towing it (but usually only going 8-10 knots).
Use a good knot on the towing line that you can untie easily
after the tow.
Seadoo specifically says to clamp the water intake before towing to avoid water intrusion. Tony, you've been lucky. One of these days, you'll hydrolock your engine and then you won't be lucky anymore. Simple to clamp the intake.
We have a yamaha vx110 4 stroke. You MUST clamp the intake or you will force water into the cylinders. We used to tow it with our old boat. I added a valve I got from the hardware store. Just cut the intake hose put the valve in place and shut it each time we towed.
Worked great for the couple of years before we got the sundancer.
Ken
Nice pliers. Never saw them or heard of them. Thanks for the info.
The SeaDoos have closed cooling so you won't get water intrusion as easily as the open cooled Yamahas.
I agree but not all do, the newer ones do for sure I broke down last week and I had to tow it home. Knowing it's a closed system I wasn't concerned but I have been told that the Yamaha units need to be clamped.
As it happens I sucked up rocks into my intake I thought I trashed the pump. During the tow home it blow out the rocks and all is well.
bingo! At any rate, I sold her late last year so....
My 2005 is GTI is not closed cooled so I need to clamp the intake to tow.They didn't use closed cooling until 2006 :(.
