towing with a van.
alk
Administrator
Staff member
Does anybody tow with a van? I'm thinking about getting rid of my SUV, and getting something a little sportier for day to day driving; and I've always wanted a conversion van for tailgates, etc. The 2500's with 5.7's can tow 7,500 pounds, which is more than enough for me -I'm about 3,500 for the boat and fuel, another 1,000 for the trailer.
I almost never need 4wd in my suv, but back when I had a pickup, I remember spinning the wheels at times on the ramp in 2wd. I haven't seen any vans with 4wd. Is it needed? Is the visibility a problem when backing down a ramp, without all the windows in a suv/pickup? Anything else I should be concerned about?
If you think an SUV guzzles gas you haven't driven a conversion van yet...
However they ARE good tow vehicles. The mass of the conversion van helps break the wind for the tow, and the long wheelbase makes for easy handling on the road; not to mention IMO they're way more comfortable. My old GMC 2500 van got better gas mileage with a travel trailer than my Dakota pickup. Some vans are available with 4wd but they're rare, at least around here. The extra weight gives good traction though, even with 2wd.
Rear visibility is not that great, but if you use those big mirrors you shouldn't have a problem. If you're a "look over the shoulder" guy you'll have to re-train.
I have a 1 ton GMC van. It's got a 4.10 differential so it's not good on mileage but I wouldn't have anything else for towing my boat. You can open the doors to have an unobstructed view when backing and you NEVER get your feet wet cuz you simply walk thru the van and step on the trailer.
I'm not too worried about mileage, I'm towing a boat after all. The ramp I mostly use is about 25 miles from my house, so whether I get 8 mpg or 15 won't matter much.
I am a "look over the shoulder" guy, only because I keep whacking the mirrors off my Tahoe.
My uncle tows a Trophy WA with his Econoline. It's 2WD, and I don't think it's even got a locking rear. No problem at the ramp, due to the weight of the rear of the van. Same as anything else- just don't get the tires wet...
My fishing buddy bought an '03 Chevy 3500 Van with the 6.0 liter gas engine. It is 2WD. It tows his HydraSports 2500 WA very well indeed. This rig is 7500-8000# on the trailer, depending on the fuel load. Never had a problem on the ramp and the van has loads of room for fishing gear dry and locked up.
thanks everybody, I think I'm going to do it. It's surprising how cheap used vans are, compared to SUV's, and even pickups of the same vintage. Now I'll need a car too, but I guess that conversation will take place over on NBR, as it's not boating related.
A van with 4wd, sure take a look at Quigly Conversions, they have been doing it for a long time. Thier conversions are top notch.
I was going to buy one a while back, but the height issue and the fuel mileage stopped me.
I have a van with the 'old' 8.1 and it tows a large cargo trailer with great ease.
Almost as good as the old power stroke.
IMHO the 5.7 is a poor engine to tow with. Look around for a newer 6.0.
I tow with a Ford E-350 with a V10. It tows great.
Gas mileage is good and no different than my V-8 van.
Mine is a window van so visibility is not a concern.
A conversion van might be a little harder to see out of with curtains and such....
The 3/4 and 1 ton vans have stronger brakes than the 1/2 ton vans.
I tow with both a Road Trek 3500 Van conversion and a 30 foot RV (with a back up camera on the RV and the boat)--no problems towing with either, as long as you have the appropiate hitch. I have never found visability to be a major problem. Be a little careful about the capacity of the van--both the towing capacity and load capacity. Sportsmobile has several 4 x 4 used diesel conversions.
I used to tow with a Chevy 3/4 ton van and it pulled nicely, however visibility (especially backing) wasn't good and it had poor traction on a wet boat ramp. I usually had everyone in my party pile into the back of the van when I pulled the boat out of the water to keep the wheels from spinning.
I had an Astro van with a conversion. That conversion made the Van a little unruly in places. Kinda Top heavy.
But it was handy too and very quiet. Somehow whatever they did in the conversion cut out a lot of road noise.
The 4.3L engine was good on gas. I only had a few hundered Lbs of boat n' trailer though.
