Trailer Tires
rgramjet
I have a Cox trailer and its time for tires. I only use it for occasional boat hauling (ie 1-2x per year. Can I just use radial regular car tires? 7,000 lb trailer with a Monterey 262, 5500lbs dry weight.
Thanks in advance!
No, you really need to use trailer tires, with the "ST" designation. The sidewalls are tougher and can handle larger loads than are typical on a car.
Bob's right. Don't do it. Goodyear Marathon are my recommendation too, vs bias tires.
even if I get "D" rated radials? One on my trailer are rated for 2045+- lbs per tire.
Steve and Bob are dead on. Don't use car tires, regardless of the rating. As already mentioned, stick with a trailer tire with the "ST" designation. Goodyear Marathon's are a good choice. Why use a car tire and then complain about how it tows/blows???
