When you look at the winches (unless you order it online) inspect the inner edges of the spool that the strap winds up on and be sure there are no sharp edges. I bought a brand new winch direct from EzGo trailers and the second time loading it cut my strap almost all the way in two. I had to take a grinder and smooth out the inside edge of one of the guides. It was as if it were put together backwards or something. Just check your boats weight to figure out the rating. Better to have a higher rating than not. I don't think the cost is much different when you consider the life span of the winch.
