Transmission fluid
Dennis M
How often do you guys change your transmission fluid and is it a difficult procedure?
Every dedicated trans guy I've ever talked to said all they recommend is draining what comes out of the pan and replacing it, as well as cleaning (or replacing) any accessible filter. It's messy unless you have a lift, or are really nimble on your back. Every 50k is when I do it in my wife's car. Others will tell you you never need it, as long as you don't beat on your car, or do anything which results in high temps in the trans. What color is it? How many miles? What kind of driving?
I have Hurth 800's and have changed fluid and filter last spring and will probably do it again this spring. If you have burned smelling fluid it must be done and don't forget to check the health of your transmission cooler.
I feel like an ass. I spent all night on an old truck forum, and now I respond this way on a boat site. Sheesh!!
on my boat it is easy to change with the same vacuum tool used on the engine.
