Transporting Houseboat
dgyomory
I am looking for input on the idea of having my 1979 48ft houseboat moved 700 miles. I have talked to a few different people and opinions seems to vary on the idea. Has anyone had this done and can share their experiences or knowledge.
There's a guy on another "alphabetical" boating forum that goes by the name "Frantically Relaxing". He recently moved a big houseboat quite a long way. Google his screen name and it should take you to him.
You are going to need a flatbed truck, a lot of permits and an escort from water to water. We moved a 43 ft Nautaline about 20 miles. We used a 5 axle trailer and a heavy duty wrecker. Still had escorts and I rode on top to watch for low clearance.
Total air draft will most likely need to be less than 14'. A 'lowboy' trailer will be a must though hydraulic boat trailers can carry very low loads. Then there are the permits for an oversise load.
Maybe one of the houseboat manufacturers could recommend an experienced hauler who could provide a quote??
I don't know where you are, or where you need to move, but there's a ton of houseboat moving companies based around lake cumberland, KY. search the somerset and monticello areas.
Those fellows down there move ships. Some of those houseboats are over 80 ft long. If that nautaline has a fly bridge on it as ours did you will have to consider removing it to get clearance under some bridges. 700 miles. That is a move. Good luck on it and take some pictures to post.
we came across someone who apparently didn't believe in the remove-it-before-it-hits-something philosophy...last summer leaving lake travis. 45' or so houseboat with a mangled mess of supports for whatever they didn't want to take down, couldn't really tell what it was. they made it to the park exit and caught the first set of lines. tied up traffic for almost 2 hours, in July in TX, and we were stuck in the exit lane or we could have dropped our boat back in.
This is no problem for boat trasporter.. Typical bridge cearance 13'6 More is possible but requires planning. Going to be expensive though.
