Tricks for refueling
  • Thread starter Thread starter blouderback
  • Start date Start date
B
blouderback
Guest
Anyone have some good tricks or tips for refueling? No matter how hard I try, and how careful I am, and how slowly I fill the tank, I always get some spillage.
Check the vent on your fuel tank. It might have a kink or clog in it.
Do you try to listen to the fuel going in and when the sound changes you know it's almost full???
Jonathan
Yes, I stand right next to the fuel spout (remember, I'm on a trailer so I'm usually doing this at the WaWa gas station), and I pry open the little rubber seal thingy on the pump spout so I get a good listen. As soon as I start hearing it gurgle, I immediately stop, but I still get a bit of an overflow, usually all over the side of the boat. :(
Ther is a "thingee" that stick to the side of the boat via suction cups and covers the vent hole and will collect the overflow.
Tiaras have a special vent that catches the overflow and sends it back to the tank. I've seen something similar in a categlogue. It connects to the vent line.
Captain Ed
I use one of those thingies and haven't spilled a drop of fuel in years. Works great. Unfortunately a Google search on "overflow catcher thingies" doesn't help!
Check your vent hose, I bet it has a loop in it or is kinked. You shouldn't have this problem.
Jonathan
if that happens before the tank is full, it's usually because of a restriction in the vent line. The most likely culprit is usually dirt or corrosion in the screen on the vent fitting. otherwise check for kinks in the line.
the only solution maybe to slow down the rate of delivery.
The device sbw1 describe is pretty neat but requires an extra hole and may not solve a vent restriction (assuming we're talking aboutthe same thing...)
it looks like a regular fuel filler but when you open it you have a piece of hose you can pull out and put in the filler. as fuel gargles out of the vent, it goes back in the filler.
it helps but if you overflow, you will still get some fuel backing up the filler although wrapping a rag around the nozle will limit damage.
personally, I strongly feel that a few drops of fuel aren't going to harm anything, it will evaporate right away... but that's a very unpolitically correct theory...
I don't think it's a clogged vent thingy. It only happens at the point when the tank is filled. I guess I'm just not quick enough to shut off the flow. Maybe slowing the rate of delivery will help, but I think I'm already being pretty careful.
you should know how much you're going to need based on how long you ran the boat so when you get to 90% of that, you may want to slow down.
If you do not want to buy one make one, all ya need is an obsorbant pad, cut a nozzel size hole in the middle of it for the fuel nozzel, cover the fuel opening with the pad while the nozzel slips in the middle while filling, any burps will not get past the pad.
ps, rather then cut a hole in pad, just make a small slice so the nozzel will have a tight fit
The pump handle is supposed to stop automatically when fuel backs up into the spout. If you have the handle fully seated on the fuel tank inlet there should be no trouble. Yesterday I filled both tanks up and only one side overflowed. It was my fault because I resqueezed the handle to make sure the tank was really full. The tanks on the 59 have narrow inlets so I must fill slowly or the fuel backs up early and stops the pump. She also has the newer nice round flat covers that require the use of a big screwdriver to turn them off so planting the fill hose is very easy. You're supposed to get the same amount of fuel whether you pump fast or slow. You should be able to set the nozzle to the first automatic step on the handle and it will fill and stop by itself. However, I have had pickups that were a real pain, I would have to turn the pump handle upside down, sideways, or even partially remove it from the tank to get enough flow to keep the pump on.
The problem is more common than you think.Poor design is the cause,my last two boats were purchased new and did this from day one. There are different ways boat owners try to prevent this from happening.My way is to watch the fuel gage while I pump fuel. As soon as the gage reads full I pump a couple more gallons and stop. My tank is 9/10 full and that's enough for me. After doing this for 7 seasons no spills!
Fred
Why don't they put the vents higher on the hull? They always seem to be lower than the deck plate. Fuel comes out the vent before it comes back up the fill pipe.
I'm with Bob again (weird isn't it?).
Bobby, I have the following assumptions.
1.) You have checked the vent line a million times.
2.) You are not spilling out the vent, but the Gas filler.
I'm betting its just a poor design. On one of my prior boats I had the same horrible problem. After I replaced the fuel tanks I had the opportunity to do a couple things.
1.) I increased the size of the vent hose and re-routed them to reduce kinks and make the turns more gradual.
2.) Add a racor internal vent overflow device. They work really well, but again this is for vent that are located BELOW the fuel fill location. If your vent is higher than the fuel fill, then you don't need one. Bowriders seldom allow the vent to be placed higher though.
3.) See if you have the height or ability to re-route your fuel inlet hose to reduce kinds. If you can't re-route it, can you increase the size of the hose? Even if ultimately you have to reduce the hose size into the tank, a larger diameter hose handles the kinks better and acts like a longer hose providing more of buffering effect.
On a low gunnel bowrider the distance between the tank and the fill is often not very great in height, while having to run horizontally and around corners. The designers may not have had a very good footprint to design around. That, and quite often, it's not really designed, just thrown together based on what fits the easiest (not what works the best).
If I only had one thing I could do, it would be to increase the size of the vent hose.
bp
I know the capacity of my fuel tank and I know the approximate consumption rate, so I fill based on that knowledge. I also use a rag in case I'm wrong. really low-tech, but it works and doesn't cost much.
Back in my Blow Boat days I would refuel while underway at sea in the worst of conditions and NEVER spill a drop. This is so simple you will kick yourself for asking.....
Step one:
take a fuel hose and squeeze ball used for outboards, remove both end fittings
Step two:
locate and secure (if underway) fuel can near fuel/deck fitting
Step three:
place fuel hose in fuel/deck fitting (make sure flow thru sqeeze ball is from can to boat)
Step four:
place other end of fuel hose in fuel can
Step five:
Prime the fuel hose and let gravity do it's thing
No spills and no back pains.
El Sea
