Trilux 33
ALKA2710
I painted my outdrives with Primacon and than coated with trilux 33. My question is what happens if you get some trilux on the stainless steel trim hoses. Will there be corrosion? do I have to remove it.
Al
I have the feeling it will come off without the primer under it. I had 33 on everything under a 35, and two areas that weren't primered properly, came off after a month of cruisin. It didn't last on props either, but shafts/rudders and tabs were fine.
