From their web site: "Roplene construction uses low-density polyethylene, which has five times the impact resistance of fiberglass, is significantly less expensive overall and 100 percent recyclable. The process produces few, if any, air emissions, whereas open-face molding, the most common method used to build fiberglass hulls, is labor intensive and releases regulated emissions. The Roplene process begins with a specially formulated polyethylene compound powder, which is poured into a high-temperature mold. The mold is mounted in a large convection oven and rotated both vertically and horizontally. The oven's heat melts the powder, which forms the boat. The mold continues to rotate during the cooling stage to ensure an even, consistent thickness."
Same basic stuff that kayaks and other such rotary molded things are made from. The complaints date well back before 2004 - you probably read about 2000 and 2001 problems or earlier. The problem with the CC is that they used inserts in the mold to fasten the CC to the hull. Because of the flexing - the bolts would back out of the inserts. I like the boats for several reasons. First, they are cheaper than the equivalent fiberglass boat. Second, the manufacturing process is automated and computer controlled, providing consistency that you can't get from hand laid fiberglass hulls. Third, no blistering. There is no layer of gelcoat to crack or blister. The Sea Tow boats were actually molded out of yellow polyethylene. They never have to paint them.
ITK, is that your boat or did you just pull the photos off the internet somewhere? Those problems don't just happen - there's a story there.
