I am looking for an inexpensive TV antenna to mount outside of my boat. Just looking for the local stations and can't deal with the rabbit ears anymore. My boat is a flybridge without a radar arch. Any ideas?
I am using a small Glomex it is great for stations within 20 miles. I have it mounted on my hardtop, in your situation you may want to mount it on a heavy duty 3 or 4 foot extension with a ratchet mount. My Glomex is I think the 10" model with a pre-amp/switch box that mounts in the boat. I am suprised how well it works with Digital stations but with digital you either have a great picture or none at all. Take care. Bill
If the TV has a digital tuner (newer TV), no converter box will be needed. Older TV's (guessing about 2005) with only an analog tuner will need a converter to receive channels directly off air with an antenna.
What model do you have? I am looking at the "Shakespeare 2025 TV Antenna". I plan on mounting it on a pole on the side of the flybridge. I am assuming the higher, the better.
Go to Radio Shack. I bought one for about $50.00 bucks, works well. It's about 6" X 12 " an about 1 1/2 inches thick, mounts on a little stand, works good enough to get local Analog and Digital stations.
