TV Antenna
I know this has been covered before but I guess I'm just think and it didn't sink in. I replaced both TVs on board this week hoping that I would get at least a few channel using the existing off air antenna but no luck. I don't even get one channel clearly. The TVs find three digital signals but can't lock in the signal. The antenna that came with the boat is a small UFO not sure what to try next. The wiring is fine I tested all the cables and even tried to bypass the splitter but no luck.
Any thoughts or advice appreciated.
Contrary to popular belief it takes a stronger (higher quality) digital signal than an old analog signal to lock the channel in. So if you had poor to so so reception in the past you probably won't do any better with digital in fact you will do worse. I normally boat in a poor area for over the air signals and have a large new antenna with pre-amp. I usually turn on my KVH TracVision M3 when I want to watch TV.
I guess this depends on where you are. We went from 1 snowy channelt to 25 crystal clear channels.
I have an outdoor Phillips antenna I bought from Walmart. The thread is here somewhere.
Needs to be boosted with an inline amp.
I went to the local Radio Shack and when I bought that same antenna they told me I would probably be brining it back because we have few stations in this area. It was worse than my Shakespeare amplified large UFO (new this year).
I had a smaller Glomex amplified UFO and it was about the same as the new Shakspeare.
Originally posted by dashizzzkat
im a few boats over from you and getting around 14 channels using this antenna
http://www.radioshack.com/product/index.jsp?productId=2253765
what channels are you getting I would be happy to get 4 channels if they are ABC,CBS,NBC FOX. With digital programming each of the above have 2 to three of there own channels.
But I gain I try anything.
Don't you need a digital antenna to get a digital signal?
as long as you have a digital tuner all you need is a UHF antenna to get digital signal.
I ordered a 15" LCD TV(TFT screen) so it's a little limited in viewing. I'm gonna have to work out an antenna for it, too, but we have good reception in this area... but I suppose it's not possible to hook up the GPS to it, huh?
The religious channels have a lot more power than the network channels.
I tried a "digital" antenna and discovered my old rabbit-ears worked better.
There is no such thing as a digital antenna. It's all marketing.
Having said that, you may need a stronger antenna to receive digital signals. Analog signals may be weak but still watchable. Digital is either perfect or not watchable at all.
I tried out my new 15" LCD digital TV with built in DVD with my 3 year old Triax UFO Marine amplified antenna at the Thimble Islands this weekend and the TV scanned and locked in 30 channels of which 15 to 18 were not only crystal clear they were as clear as my TV at home. Even as the boat swung with the wind and tide I had very little interference which only happened on 2 of the good channels. On the digital TV this means either you have the picture or you don't, for these 2 channels it meant the picture froze or pixilated for two or 3 seconds every few minutes. Of course the TV stations I received are pretty varied; two channels are 24 hour weather channels, one that shows a full screen real time weather radar with the standard NOAA marine weather broadcast as audio, a worship channel, a Spanish channel, a couple of shopping channels a cartoon channel, with the rest being an assortment of local network channels and even a couple of movie channels (mostly 70's, 80's & 90's movies). I am very happy with the results and know that without the amplified antenna and just the stick antenna that came with the TV I got only 4 or 5 digital channels as many as my old analog TV would receive when using the amplified antenna. I suspect that being close to a city or metropolitan area will mean you get more channels, the Thimbles are about 8 to 10 miles from downtown New Haven, but I even get a couple of Long Island stations from more than 20 miles across the sound.
Try this homebrew antenna. Build it and place it high, but inside the fiberglass, as far away from wiring as you can manage.
a) it is cheap. ( A big plus in my book )
b) it works.
c) it is -not- active, and does not require a power supply.
d) frankly, it should work as well as an amplified antenna.
e) if it doesn't work, hey, it was nearly free anyway.
f) If you hide it, it doesn't matter how it looks.
g) ( old retread complaint ) Heck, you are on the boat, Why would you want to watch the TV???
I have nothing except a couple of snowy analog channels. I was hoping that the UFO/UHF antenna I have would do the trick, No luck. I had seen a few post that said some people at my marina have had good luck doing this but clearly I will have to try another antenna.
dashizzzkat I was at the marina today and it looks like you have a Glomax ant not a Radio Shack I would be very happy with the channels that you receive until I spring for Satellite, which may be a while.
One more thing, then I'll bail out of this one:
UHF is quite line of sight. More so than VHF. Further it can both be blocked by tall objects and can be reflected as well. This means that reception is very much location sensitive. It is quite possible that, in your slip, you can receive virtually nothing, but the boat two slips away, with the same identical set-up will receive 30+ channels. Before you trash your existing equipment, see if the issue is your location, rather than the equipment, because if the issue is location, it won't matter what antenna you have, your reception will not change.
