TV Antenna
Tumbling Dice
Happy New Year Everyone,
We want to replace the TV antenna we have on our 35 foot Carver Mariner. We keep the boat in the California Delta. Any suggestions? The current antenna is mounted on the radar arch.
Thank you in advance for your suggestions.
Most of the Sacramento market broadcast TV stations are on the high towers south of town in Walnut Grove. In fact, you can see those towers at night from most locations in the Delta, so digital TV is easy to get regardless of antenna. I wouldn't bee surprised if some Delta folks get TV with their teeth.
Most of the San Francisco TV stations are beamed from Sutro Tower in the city.
I usually hang out in the central Delta not far from the San Joaquin River. I get all of the Sacramento/Stockton digital stations and several San Francisco stations on the boat with rabbit ears and a digital converter. Any of the marine omnidirectional antennas (like Shakespeare) should do fine on your boat.
If your current antenna isn't doing the job it may be an amplified antenna with a dead RF amplifier. Without an amplifier many of these antennas don't work as well as non-amplified rabbit ears. The metal sheds used as covered slips in marinas can be signal killers, but I get TV and radio in the slip just fine.
Have you seen the DIY antenna made from coat hangers, SS screws & washers on U-Tube & some boating forums? Many are saying they are getting much better reception than commercial antennas.
I keep my boat in Sausalito and I was getting very poor reception because the marina is too close to the hills. I had to switch to a satellite antenna and then get Direct TV. It works very well.
For the delta I think that a good regular antenna would work fine because the land is flat.
I wouldn't be surprised. I can get about half of the local digital channels perfectly with 10' of coax alone: that's before connecting the antenna.
