TV ANTENNAE
  • Thread starter Thread starter ro
  • Start date Start date
ro
I think this one has been asked,but here goes This probably has been asked many times,but here goes again.
Just bought new TV/DVD for the boat and am trying to get an idea what everyone is using for reception while on the hook.
Not looking for a permanent mount situation(no arch),just something for an occasional news cast.
Live in east central Fla and stay alot at Ponce Inlet.
The Shakespeare 2020 14" Omni-Directional TV Antenna works very well for me.
I just hooked up a 2025 on my new digital flat screen tv dvd I got the 2025 as it said it was digital the normakl channels come in somewhat fuzzy but the 12 or so digilat channels are good as cable!
We just stick a set of rabbit ears on the bridge. That's only a problem if the boat is swinging at anchor a lot. Rabbit ears are a no-gain, directional antenna but if they work, they work. We usually watch only the news and DVDs during mosquito time.
$10 rabbit ears from Wally-Mart works great as long as you are within 10 miles of land. If you new unit is an HD T-V the new HD portable antenna works as well as cable.
Thanks for the info.
Any one brand over another or are they all about the same?
I have heard Radioshack makes a $20.00 directional TV antenna.Waiting for a reply as to that being official and will post response.
good point brought up to get a digital antenna as anolog signal will be over in 2009.
Analog or digital signals can be received with the same antennas as long as the frequencies used are the same. Digital TV (VHF/UHF) or FM broadcasts will not use frequency segments different from the ones currently in use for analog. RF is RF.
http://www.dtv.gov/consumercorner.html
Yzer is correct analog and digital antennas are one in the same. Antennas receive frequencies and are by design for TV broadband, so either branding will work now and in 2009! Regards Bill
I have a question on the same topic. I want to mount a small LCD flat screen TV inside my boat. Do I need a digital antenna? Where is the best place to mount a Shakespeare 2025 type antenna if that is the type that I need? Does it need to swivel or anything like that? I don't have a radar arch.
The only antenna that ever worked for me was a Radio Shack thing shaped like a giant bat wing. It worked sometimes. Everybody laughed at us. I sold the boat antenna and all and installed a satellite on this boat. We're happy now and people don't laugh at us anymore...well at least not at my antenna;-]
32 carv from what they say i spend the extra for the 2025 and didnt need too. actually i tried the dset with a set of rabiit ears i had and got some channels with them I mounted the antenna on the front of my bridge, I was thinking of a antenna mast but didnt think the round antenna would look well sticking up on the side of the bridge over the top.
Just to keep things in perspective: remember that TV stations have little interest in broadcasting their ( very expensive ) signal over large expanses of water, so do not expect perfect performance. In addition, TV signals are line-of-sight, which is another limiting factor. Close to shore, and on inland waters, signals should be ok, but for coastal boaters, I doubt you will get a good signal 25 miles out, while trolling...
Boaters who are offshore should consider taking DVDs if TV entertainment is important to you.
I sure wouldn't throw out the Shakespeare 2025 if I had one. It has a couple of advantages over rabbit ears.
1. It's omnidirectional. When your boat is swinging at anchor, the TV picture or FM radio will not fade.
2. It has a built-in and adjustable 20db RF amplifier. When the amp is on and turned up part way, it will offer the same signal strength as rabbit ears. When you turn the amp to higher power it can make weak signals more usable than with rabbit ears.
However, when the 2025 amp is not turned on the signal will be weaker than with rabbit ears. RF amps will slowly weaken and may die after years of continual use. They should last an long as your TV, though.
You can also get an inexpensive RF amp for rabbit ears or amplified rabbit ears. Radio Shack has them but I haven't seen any that run off of 12VDC. Then again, I haven't looked for them in a long time.
I boat in the same waters as yzer and also just use rabbit ears. It all depends on where the broadcasting antenna are located and what is between your boat and that point. About the highest thing between me and the broadcast point are some tall trees.
If your really into watching TV I would recommend installing a satellite system. Since my wife and I spend 4 nights a week on our boat and we like watching cable type news and shows the KVH TracVision M-3 has been the ticket. It works well while moving and miles off shore. We have only lost the signal once during a severe storm and that was only for a few seconds. We also get the local channels through the dish on the bottom 10 or so channels. It is expensive but for those that have to have cable type TV this is the way to go. Regards Bill
I am going to try running a SLING BOX setup from home next year. Take your laptop PC to the boat with an internet card via one of the providers. Be sure to get one with enough capacity to transfer tv signals. Transfer into your TV and walla! Friend of mine does this from Florida to Germany where he lives - works great there, should work well on a boat.
Don't use VZW/ Verizon they have terminated customers for this type of use. I'm not impressed with watching streaming video from a small laptop screen either. To each his own. Regards Bill
Run your LCD TV as an external monitor to your laptop and you get past the small screen problem using Slingbox. Not sure how your land based cable/satellite provider would know. Especially if you use a DVR at home to record your favorite shows. But you do need decent broadband Internet connectivity.
