Just a quick technical comment: Broadcast TV is, like marine VHF, direct line of sight.
Given that many boating areas are not near mountains ( hey, I'm a flatlander, 200 ft is a mountain, ok... ), the only antenna height is the actual tower height. Most ( all? ) antenna towers are 2000ft or shorter. Running that through the line of sight calc give an absolute max range of around 60 miles. Subtract for power loss at a distance, and the fact that the tower is unlikely to be "aimed" at open water, and your range will definitely be shorter. Plus, for TV you need a good strong signal.
Net result? You are going to be limited to something like 30 miles or less regardless of the antenna you have aboard. Amplified antennas will amplifiy whatever gets to the antenna. In fringe areas that means it amps the degraded signal and all of the background noise. Thus, amplifiers, while they do work, provide only a limited improvement. A taller, not necessarily higher gain, antenna will provide the best result.
--edit--
Before I get bombarded with barnacle clad rocks, I should state that the above comments are specifically about TV reception aboard boats, which move and rock...
On shore, higher gain, directional antennas are often useful, at sea, their usefulness is questionable.
