Two questions....
firepiper
Does anybody know the coolant capacity of crusader model 350 (454), fwc block and manifolds?
What is the concensus on leaving batteries in the boat for the winter? (2-8d)
They are in a tough spot andvery heavy to remove.
I was considering putting a trickle charger on them.
Thanks, Mark
For the last 25 years I have put 6 gallons thru my engines each, stats removed and I take the neg , off the batteries. It has been good for all thoses times.
Thanks. I tested my anti-freeze yesterday, it's only good to +15f. I drained the heat exchanger and the manifolds and got 4 gals. I'm trying to figure if this is about 50%, so I can fill it with AF, or, if I should drain more out first. Thanks.
I leave the batteries on board, in a barn.
They get charged at lay-up in fall, at Christmas, and again at the end of February. Has worked well for me.
Peter
Peter, I just looked it up in my Crusader manual and they list "Fresh Water Cooling System Capacity" as 33Qts! That must be blocks, hoses elbows and manifolds, oil cooler and heat exchanger. Sounds like a lot. When I drain my blocks down and backfill with antifreeze, I get about 3 1/2 gallons back into each block.
I keep my batteries at home connected to a trickle charger/maintainer. My son-in-law leaves the batteries on his 34' Cruisers because they are almost impossible to remove. He disconnects the negative wire and runs a charger once a month for a day. He can't leave a maintainer connected because there's not electric receptacle near his boat at the marina. He has to connect a 100' extension cord to get juice to the chargers. Either way works.
