i found 2 small dime size holes at the
corner trailing edge under the water level
just into the mess area
can i patch with regular fiberglass and cut a small patch and roson 1 or 2 layers should bring it up to surface
if iam on the right path, then do i just build it up above the hull surface then
just sand that area? it must of happened when loading on the trailer today
thanks in advance
thanks in advance
